Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
Seems a bug in the plugin, thank you for reporting it |
Joined: 09/05/2019(UTC) Posts: 8 Location: South Tangerang Was thanked: 3 time(s) in 3 post(s)
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
Hello Susilo Widyatmoko, Originally Posted by: Susilo Widyatmoko can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable. Edited by user 30 December 2021 03:32:24(UTC)
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word. In order to be able to arrange and organize formulas and text better, I use text regions. Unfortunately, text regions containing formulas are not saved properly in the *.odt files. Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much Raimund
Hello
RaiHil
Originally Posted by: RaiHil Unfortunately, text regions containing formulas are not saved properly in the *.odt files. Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files? I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side. |
Originally Posted by: Davide Carpi Hello
RaiHil
Originally Posted by: RaiHil Unfortunately, text regions containing formulas are not saved properly in the *.odt files. Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files? I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side. Thank you, I appreciate your effort!
