Offline johnspark
#1 Posted : 28 September 2021 10:10:58(UTC)
johnspark
Australia
Was thanked: 5 time(s) in 3 post(s)
Hi All,
this is my first post. Have chosen to jumpstart learning Smath via the Maple Add-on.
Hope this is useful to other newbies.
Kind Regards
Johnspark
MapleVLearningGuide.sm (142kb) downloaded 63 time(s).
thanks 1 user thanked johnspark for this useful post.
on 28/09/2021(UTC)
Offline uni
#2 Posted : 28 September 2021 10:22:50(UTC)
uni
If you enable debug mode ( <Debug>True</Debug> ) in the configuration file MapleTools.config, then a log file will appear in which you can see how the function works. This file is overwritten when the program is closed, so you need to modify it when the program is not running. Also in the plugin folder you can find win.inc file in which you can include packages. This cannot be done with a separate command.
Code:
%appdata%\SMath\extensions\plugins\32dfd679-8cfd-483a-b79a-19d5ea838750\x.x.x.x\
Edited by user 28 September 2021 10:24:55(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#3 Posted : 28 September 2021 14:10:03(UTC)
Thanks ... lot more codes never explored before.
You can visit Samples Symbolic COMPENDIUM for + posted few days ago.
Just that one doctored wrt Maple code.
Take care ... Jean
#4 Posted : 28 September 2021 14:53:08(UTC)
You mentioned conform to book style.
Most book style are in reverse order of Lagrange.
Lot numerical maths go by Lagrange:
Cubic solver, Polyroots, Cholesky polynomial fit ...
Offline johnspark
#5 Posted : 28 September 2021 15:15:51(UTC)
johnspark
Australia
Code:
Thank you uni for your lightning response.
I have gone through a number of Maple messages in the forum and i am having a bit of difficulty finding these files. So far i have as seen below:
I have not been able to find the MapleTools.config so far.
Kind regards.
#6 Posted : 28 September 2021 15:22:08(UTC)
The best irony of incorrect book style:
Most CAS functions [ln, trig ...]
are Padé normalized rational fractions
NUM, DENOM are Lagrange style in ascending order.
Offline johnspark
#7 Posted : 29 September 2021 02:36:53(UTC)
johnspark
Australia
I agree about the ascending order, that's what i have always been used to. Glad you found some help in the file Good.
#8 Posted : 29 September 2021 02:47:49(UTC)
I agree about the ascending order, that's what I have always been used to. Glad you found some help in the file
Thanks Collab,
I will revisit for many new Maple codes.
What was developed in Smath Community is
more oriented to projects.
Take care ... Jean.
Offline johnspark
#9 Posted : 29 September 2021 14:38:01(UTC)
johnspark
Australia
Code:
Kind regards.
Got some better progress tonight:
UsingMapleLogToSeeHowFunctionsWork.docx (195kb) downloaded 17 time(s).
on 30/09/2021(UTC)
#10 Posted : 29 September 2021 14:51:34(UTC)
Please, attach the Smath document.
About combine, we have lot more in Smath.
See you soon ... Jean
Maths Combine.sm (74kb) downloaded 27 time(s).
#11 Posted : 29 September 2021 15:06:23(UTC)
... about GCD, LCM as well
Maths GCD-LCM.sm (18kb) downloaded 26 time(s).
