SMath Studio Forum
Samples
Maple V Learning Guide examples via Smath Worksheet
Joined: 26/09/2021(UTC) Posts: 66 Location: Adelaide Was thanked: 5 time(s) in 3 post(s)
Hi All, this is my first post. Have chosen to jumpstart learning Smath via the Maple Add-on. Hope this is useful to other newbies. Kind Regards Johnspark MapleVLearningGuide.sm (142kb) downloaded 62 time(s).
1 user thanked johnspark for this useful post.
If you enable debug mode ( <Debug> True</Debug> ) in the configuration file MapleTools.config, then a log file will appear in which you can see how the function works. This file is overwritten when the program is closed, so you need to modify it when the program is not running. Also in the plugin folder you can find win.inc file in which you can include packages. This cannot be done with a separate command. Code:%appdata%\SMath\extensions\plugins\32dfd679-8cfd-483a-b79a-19d5ea838750\x.x.x.x\
Edited by user 28 September 2021 10:24:55(UTC)
Originally Posted by: johnspark Hope this is useful to other newbies. Thanks ... lot more codes never explored before. You can visit Samples Symbolic COMPENDIUM for + posted few days ago. Just that one doctored wrt Maple code. Take care ... Jean
You mentioned conform to book style. Most book style are in reverse order of Lagrange. Lot numerical maths go by Lagrange: Cubic solver, Polyroots, Cholesky polynomial fit ...
Originally Posted by: uni If you enable debug mode ( <Debug> True</Debug> ) in the configuration file MapleTools.config, then a log file will appear in which you can see how the function works. This file is overwritten when the program is closed, so you need to modify it when the program is not running. Also in the plugin folder you can find win.inc file in which you can include packages. This cannot be done with a separate command. Code:%appdata%\SMath\extensions\plugins\32dfd679-8cfd-483a-b79a-19d5ea838750\x.x.x.x\
Thank you uni for your lightning response. I have gone through a number of Maple messages in the forum and i am having a bit of difficulty finding these files. So far i have as seen below: I have not been able to find the MapleTools.config so far. Kind regards.
Originally Posted by: Jean Giraud You mentioned conform to book style. Most book style are in reverse order of Lagrange. Lot numerical maths go by Lagrange: Cubic solver, Polyroots, Cholesky polynomial fit ... The best irony of incorrect book style: Most CAS functions [ln, trig ...] are Padé normalized rational fractions NUM, DENOM are Lagrange style in ascending order.
Originally Posted by: Jean Giraud You mentioned conform to book style. Most book style are in reverse order of Lagrange. Lot numerical maths go by Lagrange: Cubic solver, Polyroots, Cholesky polynomial fit ... I agree about the ascending order, that's what i have always been used to. Glad you found some help in the file .
Originally Posted by: johnspark I agree about the ascending order, that's what I have always been used to. Glad you found some help in the file Thanks Collab, I will revisit for many new Maple codes. What was developed in Smath Community is more oriented to projects. Take care ... Jean.
Originally Posted by: johnspark Originally Posted by: uni If you enable debug mode ( <Debug> True</Debug> ) in the configuration file MapleTools.config, then a log file will appear in which you can see how the function works. This file is overwritten when the program is closed, so you need to modify it when the program is not running. Also in the plugin folder you can find win.inc file in which you can include packages. This cannot be done with a separate command. Code:%appdata%\SMath\extensions\plugins\32dfd679-8cfd-483a-b79a-19d5ea838750\x.x.x.x\
Thank you uni for your lightning response. I have gone through a number of Maple messages in the forum and i am having a bit of difficulty finding these files. So far i have as seen below: I have not been able to find the MapleTools.config so far. Kind regards. Got some better progress tonight: UsingMapleLogToSeeHowFunctionsWork.docx (195kb) downloaded 17 time(s).
Originally Posted by: johnspark Got some better progress tonight: Please, attach the Smath document. About combine, we have lot more in Smath. See you soon ... Jean Maths Combine.sm (74kb) downloaded 27 time(s).
Originally Posted by: Jean Giraud About combine, we have lot more in Smath. See you soon ... Jean ... about GCD, LCM as well Maths GCD-LCM.sm (18kb) downloaded 26 time(s).
SMath Studio Forum
Samples
