SMath Studio Forum
Questions
How to plot graphs with different format in 3d plot?
Joined: 09/11/2020(UTC) Posts: 17 Location: Cusco Was thanked: 4 time(s) in 2 post(s)
Hi, I have to questions about the 3d plotting. 1. How to plot one graph as points and the other as lines? 2. Why my 3D surface only have vertical lines if I defined all the points for the mesh? Thanks in advance. Columns.zip (59kb) downloaded 19 time(s).
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hi Renzo. Originally Posted by: Renzorex 1. How to plot one graph as points and the other as lines?
There may be other solutions but the fastest and easiest is to project the points on a 2D Plot Columns.sm (49kb) downloaded 23 time(s).Originally Posted by: Renzorex 2. Why my 3D surface only have vertical lines if I defined all the points for the mesh?
The mesh could be good for some other software, but not for the way that SMath use the matrix of the 3D plot. Do you have the parametric function for that surface? Best regards. Alvaro. Edited by user 21 October 2021 06:26:07(UTC)
Thanks for the answer. I still not defined the function in smath, firstly I wanted to figure out how to make the plots, now I'll look out more post about the 3d plots in the forum.
Originally Posted by: Renzorex Thanks for the answer. I still not defined the function in smath, firstly I wanted to figure out how to make the plots, now I'll look out more post about the 3d plots in the forum. You don't really need much. For a vectorial function F(x,y) = [x, y, f(x,y)] simply arrange the data as in an excel 3D chart, import it to SMath and follow the procedure in the attached file, which contains only one user function NumericMesh.sm (22kb) downloaded 25 time(s).Best regards. Alvaro.
SMath Studio Forum
Questions
