Offline Renzorex
#1 Posted : 20 October 2021 18:36:45(UTC)
Renzorex
Rank: Member
Peru
Was thanked: 4 time(s) in 2 post(s)
Hi, I have to questions about the 3d plotting.
1. How to plot one graph as points and the other as lines?
2. Why my 3D surface only have vertical lines if I defined all the points for the mesh?
Thanks in advance.
Columns.zip (59kb) downloaded 19 time(s).
Offline Razonar
#2 Posted : 21 October 2021 06:23:51(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi Renzo.
There may be other solutions but the fastest and easiest is to project the points on a 2D Plot
Columns.sm (49kb) downloaded 23 time(s).
The mesh could be good for some other software, but not for the way that SMath use the matrix of the 3D plot. Do you have the parametric function for that surface?
Edited by user 21 October 2021 06:26:07(UTC)  | Reason: Not specified
Offline Renzorex
#3 Posted : 26 October 2021 21:01:52(UTC)
Renzorex
Rank: Member
Peru
Thanks for the answer. I still not defined the function in smath, firstly I wanted to figure out how to make the plots, now I'll look out more post about the 3d plots in the forum.
Offline Razonar
#4 Posted : 27 October 2021 05:03:28(UTC)
Razonar
Uruguay
You don't really need much. For a vectorial function F(x,y) = [x, y, f(x,y)] simply arrange the data as in an excel 3D chart, import it to SMath and follow the procedure in the attached file, which contains only one user function
NumericMesh.sm (22kb) downloaded 26 time(s).
#5 Posted : 27 October 2021 15:26:31(UTC)
NumericMesh [Spline(M,x,y].sm (24kb) downloaded 21 time(s).
