Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 360 Was thanked: 30 time(s) in 29 post(s)
How can I plot 3-D diagram? So for example. See please the SMath attach! GTU-Ro-T.sm (384kb) downloaded 17 time(s).
Originally Posted by: OchkovVF How can I plot 3-D diagram? So for example. See please the SMath attach! 1. Arrays dimension do not match. 2. Once doctored, maybe Maxima.
... a bit doctored. GTU-Ro-T.sm (394kb) downloaded 15 time(s).
Joined: 15/04/2012(UTC) Posts: 1,996 Was thanked: 1132 time(s) in 727 post(s)
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1). GTU-Ro-T_Kr.sm (396kb) downloaded 11 time(s). |
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap. ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning from all of the work on plug-ins etc... hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad. enjoy the clip..i may have smoked too much at that the time i made it. In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses? Funny Orbits 3.zip (3,699kb) downloaded 8 time(s).
Joined: 28/08/2014(UTC) Posts: 1,375 Was thanked: 836 time(s) in 529 post(s)
Originally Posted by: OchkovVF How can I plot 3-D diagram? Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it. GTU-Ro-T.sm (398kb) downloaded 15 time(s).Best regards. Alvaro. Edited by user 05 May 2023 22:31:57(UTC)
