Offline OchkovVF
#1 Posted : 05 May 2023 12:29:56(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (384kb) downloaded 17 time(s).
#2 Posted : 05 May 2023 14:32:19(UTC)
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 Posted : 05 May 2023 15:25:47(UTC)
... a bit doctored.
GTU-Ro-T.sm (394kb) downloaded 15 time(s).
#4 Posted : 05 May 2023 18:11:50(UTC)
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
GTU-Ro-T_Kr.sm (396kb) downloaded 11 time(s).
Offline NewtonsMethod
#5 Posted : 05 May 2023 21:06:56(UTC)
NewtonsMethod
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3,699kb) downloaded 8 time(s).
Offline Razonar
#6 Posted : 05 May 2023 22:29:48(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
Click to enlarge
GTU-Ro-T.sm (398kb) downloaded 15 time(s).
Edited by user 05 May 2023 22:31:57(UTC)  | Reason: Not specified
#7 Posted : 05 May 2023 23:16:54(UTC)
... differently by doing what's wanted.
3D Plot.sm (62kb) downloaded 10 time(s).
3D Axes System XYZ User Explorer.sm (53kb) downloaded 11 time(s).
3D Axes System Parametric Explorer.sm (22kb) downloaded 9 time(s).
3D Solid cut by Surface.sm (73kb) downloaded 8 time(s).
#8 Posted : 06 May 2023 03:04:08(UTC)
...project 2D on 3D
Analemma [Project_Anim].sm (34kb) downloaded 6 time(s).
Analemma PROJECTION.sm (82kb) downloaded 6 time(s).
