Offline Ferdinand
#1 Posted : 23 February 2013 19:26:55(UTC)
Ferdinand
Hello guy,
In the "Units.xml" file (Version 0.95 (4594))
The unit "rpm" is defined as "pi/30 s", but I mean it would be "1/60 s", because it means "revolutions per minute" and not "angular velocity".
Similar "rph", I mean it would be definded as "1/3600 s" and not as "pi/1800 s".
And as last "radpm", I mean it would be definded as "pi/30 s" and not as "1/60 s".
Offline kilele
#2 Posted : 23 February 2013 20:01:15(UTC)
kilele
Hi, SMath's default unit evaluation is SI (rad per second). In next versions, there could be an extra option to allow the user set Imperial units or United States customary units by default.
Edited by user 23 February 2013 20:19:14(UTC)  | Reason: Not specified
kilele attached the following image(s):
Offline Ferdinand
#3 Posted : 23 February 2013 22:18:00(UTC)
Ferdinand
Yes of course
you are right, I made a mistake
thanks
Ferdinand
