Hello guy,
In the "Units.xml" file (Version 0.95 (4594))
The unit "rpm" is defined as "pi/30 s", but I mean it would be "1/60 s", because it means "revolutions per minute" and not "angular velocity".
Similar "rph", I mean it would be definded as "1/3600 s" and not as "pi/1800 s".
And as last "radpm", I mean it would be definded as "pi/30 s" and not as "1/60 s".
Hi, SMath's default unit evaluation is SI (rad per second). In next versions, there could be an extra option to allow the user set Imperial units or United States customary units by default. Edited by user 23 February 2013 20:19:14(UTC)
| Reason: Not specified kilele attached the following image(s):
Yes of course you are right, I made a mistake
thanks Ferdinand
