SMath Studio Forum
Bugs & Problems
[SS-3479] Attempted to divide by zero exceptions
Joined: 22/03/2013(UTC) Posts: 20 Location: Atlanta, GA
Originally Posted by: w3b5urf3r_reloaded Have you tried if the issue affects also older SMath Studio versions? 0.95, 0.94, 0.93, 0.92.... WAIT WAIT WAIT WAIT WAIT! WHAAAAAT?I believe I have found a problem with the SMath site. Because of this, when I tried an "older" version, I did not. If I go to download for example, 0.88, and click on the 0.88 setup here: http://en.smath.info/for...0-88--12-April-2010.aspxWhat do I get? 0.95If I try to get 0.94 from here: http://en.smath.info/for...o-0-94--18-May-2012.aspxWhat do I get? 0.95Every version I have tried to download (in the last hour) has given me 0.95.I therefore am unable to try other versions to see if the divide by zero problem is limited to 0.95. Thanks, Kyle
It's true However here there is a 0.94 version (found in C:\Users\Davide\AppData\Roaming\SMath - folder get from SettingsDirectory(#) function of customFunctions plugin) ( edit) and the first 0.95. regards, w3b5urf3r Edited by user 28 March 2013 20:28:39(UTC)
I could find download links for old versions, for example: http://smath.info/?file=739858Just go to the archive subforum on the "Download" forum Could you try to change xp look and feel, you know the style of windows dialogues, titlebars, icons size.. I think you can change it opening Desktop Properties, "Appearance" and "themes" tab. Changing this to get a more standard style, I was able to solve issues affecting user interfaces of another software.
Kilele,
The link you posted takes me to install 0.95. Yes, I too find the download links for older versions, but when you actually click to download, the files you receive are all 0.95.____.msi.
I had already tried changing to the totally default Blue theme (all defaults for screen setups) when I saw rendering issues with your Page1.sm file. When it did not fix the problem, I changed back to Microsoft XP Silver Normal.
I just downloaded and ran the NetFXRepairTool.exe from Microsoft. It said it found no problems, so I clicked the button to do what I will call deep compare/repair. It checked every file in every .Net version I have installed against Microsoft looking for any differences (took about 15 mins). It finished by saying it could find no issues with any of my .Net installations.
I uninstalled 0.95, cleaned the registry, installed the 0.94 version W3b5urf3r posted. It had the same issues rendering and divide by zero when looking at Help -> About. It wanted to do an update, so I allowed it to update to 0.95. Same results.
I have never had software to not run on this PC. This is crazy!
Thanks so much, Kyle
Aaahh, the requested older versions are hidden. You have to click a link to unhide them. Not cool. -Kyle
Quote:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.DivideByZeroException: Attempted to divide by zero. at SMath.Manager.DynamicLabel..ctor() at SMath.Desktop.About.InitializeComponent() at SMath.Desktop.About..ctor() at SMath.Desktop.Form1.ShowAboutDialog(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3643 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop Assembly Version: 0.88.3754.54 Win32 Version: 1.1.14.0 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/SMathStudio_Desktop.exe
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3645 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3644 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman Assembly Version: 0.88.3754.50 Win32 Version: 0.88.3754.50 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/ioman.DLL
HTMLFileType Assembly Version: 1.1.3753.43167 Win32 Version: 1.1.3753.43167 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/HTMLFileType.dll
canvas Assembly Version: 0.88.3754.52 Win32 Version: 0.88.3754.52 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/canvas.DLL
SpecialFunctions Assembly Version: 1.1.3753.43100 Win32 Version: 1.1.3753.43100 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/SpecialFunctions.dll
XMCDFileType Assembly Version: 1.1.3753.43032 Win32 Version: 1.1.3753.43032 CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/XMCDFileType.dll
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Is this helpful? Thanks, Kyle
Hopefully Andrey will see this log with the exception: System.DivideByZeroException: Attempted to divide by zero. and will be taken into account in the next version, It seems some problem related with calculating/placing user interfaces elements, just guessing though. You may want to install .net20 manually (I guess the install will detect if there are newer versions http://www.microsoft.com...oad/details.aspx?id=1639Another idea to test, backup and delete mscorlib at C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll and try to repair the .net installation again.
I tried several iterations. Removed mscorlib.dll from 2.0, same problems. Restored, same problems. Removed it from 4.0, same problems. Restored, same problems.
I removed them both, so there is NO mscorlib.dll on my PC and ran SMath. Same problems. What? I don't even need this DLL installed to run SMath. Search does not find the DLL. Is it cached somewhere?
I have not restored my .Nets yet. Right now, running the PC without those DLLs at all.
Thanks, Kyle
If you are not totally annoyed by the software yet or by my suggestions, you could try to upgrade your videocard drivers as well as checking out if you are using any applications that affect other software like antivirus..
Originally Posted by: kilele If you are not totally annoyed by the software yet or by my suggestions, you could try to upgrade your videocard drivers as well as checking out if you are using any applications that affect other software like antivirus.. I figure you guys are the one who is annoyed with me. I do not believe the video card drivers or anti-virus could cause a divide by zero error when I click Help -> About. Nevertheless, I checked my video card drivers and turned off my anti-virus software (Comodo Internet Security Premium). I still get divide by zero errors. Since I last posted, I took some time to upgrade NetBeans, MPLabX, Gimp, Firefox, Thunderbird, LibreOffice, Filezilla, puTTY, Zim Wiki, and Foxit Reader. All went smoothly and work perfectly with no glitches. The problem with SMath Studio is quite confounding and completely atypical for me. If the developers want to send stripped down test-compiles to locate the problem, I am open to it. I would very much like to use this program.I really appreciate everyone being so patient with me. Thanks, Kyle
oops I'm sort of cursed with the same issues as you. I wanted to see Smath in Linux in a rapid way, that is by installing a precompiled exe of a lightweight distribution: "Precise Puppy Linux 550.exe", then I searched "mono-complete" on the Pupy package manager and finally downloaded Smath and run its .exe from the console: mono smath.exe And arghh I was faced with your very same problems: abrupt exit when trying to activate menus leaving dividing zero errors messages on the console, and sheets showing all regions messed up. By the way, I've noticed that the download setup provided for Linux is actually a nice portable version which works on Windows, with the advantage of not including the entire .net framework as well as allowing the use of third party plugins! Edited by user 13 April 2013 21:19:17(UTC)
Originally Posted by: kilele By the way, I've noticed that the download setup provided for Linux is actually a nice portable version which works on Windows, with the advantage of not including the entire .net framework as well as allowing the use of third party plugins!
That is really an interesting option which I would like to recommend in my handbook. However, the settings are not stored in the dir where the exe resides as in the portable version. Instead, a settings directory is used that seems to depend on the local .net environment. I noticed that the installed version and the linux executable use the same settings dir. I added most of the available plugins to the linux distrib and packed that into a zip (3MB ) available in the wiki: SMath with plugins. This saves you from collecting the plugins from the locations spread over the forum. I only used precompiled plugins and excluded those that have licence issues or do not run on x64. Still I may have missed some plugins. I did not collect individual permissions from the authors to include the plugins but shall remove them if I am asked to do so. Also I did not perform thorough testing of the setup, but so far no indications for particular problems (in addition to those that we have with the native windows version. Depending on the response, I shall repeat this post at a more appropriate location in the forum. Edited by user 14 April 2013 12:43:56(UTC)
Originally Posted by: mkraska That is really an interesting option which I would like to recommend in my handbook. However, the settings are not stored in the dir where the exe resides as in the portable version. Instead, a settings directory is used that seems to depend on the local .net environment. I noticed that the installed version and the linux executable use the same settings dir. I added most of the available plugins to the linux distrib and packed that into a zip (3MB ) available in the wiki: SMath with plugins. This saves you from collecting the plugins from the locations spread over the forum. I only used precompiled plugins and excluded those that have licence issues or do not run on x64. Still I may have missed some plugins. Thanks for maintaining this derivative distribution with user-made plugins. It could be possible to make an alternative version to store settings in the same directory as the exe, following the instructions on the portableapps.com forum, but it might be hacking Andrey's installer too much. Anyway, I remember that he was interested in following the specifications of that software suite. The next version of portableapps will support .net applications so it will be a good opportunity to prepare an official portable distibution to promote smath on that site.
Thank you Martin If I remember my wishlist from almost three years ago, it seems that SMath version you presented here is a step forward to something I always wanted, thanking to Andrey and plugin makers ( w3b5urf3r and uni in the first place). I really hope that there would not be another three years waiting for SMath version 1.0 . I can not find the right words, but It would be really just a very sad thing not to have SMath 1.0 in the very recent future . Regards, Radovan Edited by user 14 April 2013 20:42:33(UTC)
Originally Posted by: kilele And arghh I was faced with your very same problems: abrupt exit when trying to activate menus leaving dividing zero errors messages on the console, and sheets showing all regions messed up. I am sorry you have the problem on your linux install, but happy to not be the only one with the problem. Did you solve the problem? Thanks, Kyle
Originally Posted by: mkraska I added most of the available plugins to the linux distrib and packed that into a zip (3MB ) available in the wiki: SMath with plugins. This saves you from collecting the plugins from the locations spread over the forum. kda406, have you tried to run this build? It's designed for linux but work also on windows systems. |
Originally Posted by: w3b5urf3r_reloaded kda406, have you tried to run this build? It's designed for linux but work also on windows systems. I thought so, but just to be sure I tried again just now. I tried: SMathStudioDesktop.0_95_4594.Portable.exe (Date: 30.07.2012. File size: 18M - .Net Framework 2.0 doesn't required And also tried: Desktop Linux (desktop computer with Linux OS): SMathStudioDesktop.0_95_4594.Mono.tar.gz (Date: 30.07.2012. File size: 857.25K - last version of Mono distributive required! Portable for Windows gives the same problems and divide by zero errors as the installed version. Mono/Linux version gives 4 warnings about plug-ins, then runs, but crashes the same way with divide by zero errors. Thanks, Kyle
I tried several windows installers for installing Puppy (not the .iso files) without success to run Smath. A pity because I like Puppy, just occupies a few hundred megabytes and can run totally in ram. I think it's best to use some distribution bundled with mono like Ubuntu. I'll post my finding here if I manage to make a minimum installation of Ubuntu. I wonder if installing mono for windows would make a difference in your case.
Originally Posted by: kilele I downloaded and installed Mono (no issues). I ran it as the command line version. First I pasted the path of the installed SMathStudio. It runs slowly, but comes up. It had the same issues, which I guess is no surprise as it is still using the installed .Net components. Next I navigated the Mono CL to the location where my SMath portable (for Windows) is located. I ran it, and it was much slower, as expected. But I was shocked that when I clicked Help About, I still get a divide by zero error. I didn't try anything else. Thanks, Kyle
Kyle : Have you tried to run the the Linux build with Mono for Windows ? Originally Posted by: w3b5urf3r_reloaded Originally Posted by: mkraska I added most of the available plugins to the linux distrib and packed that into a zip (3MB ) available in the wiki: SMath with plugins. This saves you from collecting the plugins from the locations spread over the forum. kda406, have you tried to run this build? It's designed for linux but work also on windows systems. You could install VirtualBox for Windows hosts and run it as a virtualmachine just fine. This is a straightforward how-to with screenshots: http://www.psychocats.net/ubuntu/virtualboxThe idea is to run some lightweight Linux distro including Mono by default, like Ubuntu. I would try Xubuntu which runs loading less ram and allows an installation of 1.5gb in case you are interested after seeing it on virtualbox, besides it makes sense to use a lighter ram version from within windows. Edit: other linux versions reported in the forum which run successfully Smath http://en.smath.info/for...run-Ubuntu.aspx#post7327Edited by user 16 April 2013 19:07:26(UTC)
SMath Studio Forum
Bugs & Problems
