Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
Incorrect Unit calculation
nik
01/02/2015 05:11:42(UTC)
7
1,233
05/02/2015 01:20:46(UTC)
Units conversion error (Celcius to Kelvin)
Alex M.
22/01/2015 03:25:43(UTC)
1
1,295
mikekaganski
22/01/2015 06:02:07(UTC)
file with error "matrix index out of limit" (translated from italian)
file corrupted with the message: "matrix index out of limit" (translated from italian)
davide47
19/01/2015 17:30:43(UTC)
3
945
21/01/2015 18:55:17(UTC)
Vector x Vector Problem :S ?
Vector x Vector giving me single answer as opposed to a column of answers
bossman3333
19/01/2015 13:16:12(UTC)
5
742
20/01/2015 20:26:10(UTC)
Working in Linux with windows' sm files
nachohp
23/12/2014 20:50:04(UTC)
1
501
Tinu
04/01/2015 21:00:23(UTC)
Open file bug
Index was outside the bounds of the array
TienCuong
09/12/2014 14:11:38(UTC)
4
668
10/12/2014 13:34:26(UTC)
Problem with units in "if" function
Cant to gain the result
Janusz
10/12/2014 12:20:07(UTC)
2
433
Janusz
10/12/2014 13:00:52(UTC)
pdf plugin export filename
After doing a pdf export, the filename becomes xxx.pdf, not xxx.sm
crun2
09/12/2014 10:14:44(UTC)
1
855
brotjob
09/12/2014 14:42:11(UTC)
[SS-1249] Summation in For Loop
Error when using summation in for loop
RFreund
01/12/2014 00:25:47(UTC)
9
2,763
RFreund
04/12/2014 01:38:49(UTC)
Plot - axis scale
kamilg1993
30/11/2014 18:05:42(UTC)
1
2,236
02/12/2014 12:14:48(UTC)
palettes and dark themes
the symbols and palette colors are set with different ways and can be incoherent
mat
29/11/2014 20:39:15(UTC)
0
349
mat
index outside matrix boundaries
cannot open file
csb531
17/11/2014 19:16:10(UTC)
3
1,373
18/11/2014 02:19:02(UTC)
error in matrix calculation and view
grelkn
16/11/2014 18:10:08(UTC)
3
635
16/11/2014 20:47:21(UTC)
Instal Plugin errorr
laikluk
23/09/2014 18:51:59(UTC)
1
565
23/09/2014 19:46:08(UTC)
ComboBoxRegion installation failed.
loading plugins
E-Jay
08/09/2014 18:30:09(UTC)
6
973
10/09/2014 02:00:46(UTC)
Guest (4)
