Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
include does not seem to work anymore
Tinu
23/06/2014 09:56:03(UTC)
2
1,184
Tinu
23/06/2014 14:17:04(UTC)
Plagins Error while loading
Basile
21/05/2014 23:59:05(UTC)
1
894
22/05/2014 16:49:34(UTC)
Bug in funtion f(x) release 97.5189
f(x) generates Summation instead of function
Gilberto
05/05/2014 15:44:56(UTC)
2
1,090
Gilberto
07/05/2014 09:21:41(UTC)
Summ(1) bug
tomtit
05/03/2014 20:15:21(UTC)
7
2,369
29/04/2014 23:04:04(UTC)
Broken File (Unexpected Error)
File cannot be open due to a unexpected error
Lu_the_engineer
28/04/2014 22:48:51(UTC)
5
1,649
Lu_the_engineer
29/04/2014 20:08:57(UTC)
Matching units blamed to not match
BTS Issue SS-26
29/05/2013 15:36:49(UTC)
25
6,328
24/03/2014 23:55:02(UTC)
faculty operator crashes smath
24/08/2013 13:25:32(UTC)
5
1,913
23/03/2014 14:05:47(UTC)
Hyperlinks not visible in forum posts
22/03/2014 17:02:26(UTC)
1
1,039
22/03/2014 20:50:50(UTC)
Reusing variable results in wrong result
midas
16/03/2014 20:21:17(UTC)
2
1,241
midas
21/03/2014 02:29:47(UTC)
[DEV:SMath Viewer] Descriptions
14/03/2014 18:37:57(UTC)
0
920
Problem with ZedGraphRegion
uham67
uham1867
18/02/2014 12:09:12(UTC)
2
1,057
sija
13/03/2014 20:32:58(UTC)
Printed documents from viewer don't show values correctly
experimentator
12/03/2014 09:53:59(UTC)
1
931
12/03/2014 23:31:56(UTC)
[SMath Viewer] Variables not defined
Can't close the executable editing an empty variable
05/03/2014 20:19:17(UTC)
0
824
Problem when closing Extensions Manager on Linux
Balu42
01/03/2014 03:57:45(UTC)
0
735
Balu42
Types coversion
@Air provides thermodynamic properties and transport properties of moist air.
tomtit
26/02/2014 00:49:56(UTC)
6
1,484
28/02/2014 03:29:49(UTC)
Guest (8)
New Posts |
No New Posts |
Hot Topic (New Posts) |
Hot Topic |
New Posts (Locked) |
No New Posts (Locked) |
Announcement (New Posts) |
Announcement |
Sticky (New Posts) |
Sticky |
Poll (New Posts) |
Poll |
Moved |
