Originally Posted by: PompelmoTell Hello Martin, I had mistakenly understood that the problem is on the plot ' geometries ' It was working fine now trying on "spannungen" plot, I have the same problem I apologize Sergio That was not mistakenly. In fact I can reproduce the problem with my uploaded file on both plots. And I can confirm that Radovans version works fine here. Unless I hide the input area and save and re-open the file. Saving the file with visible input regions seems to be safe. |
Andrey said that will fix this in the next version. |
Originally Posted by: uni Andrey said that will fix this in the next version. I think there is nothing wrong if we forget and repeat the things . As I become older the frequency of my forgetting things is increasing By the way, what about introducing some kind of "bugzilla" thing in order to keep tracking of bugs? I am not sure about it, and it seems that this Forum is still good enough for this. Regards, Radovan |
Just wanted to congratulate omorr with 100 thanks Note this number - it will surely soon be not so round! |
Best regards, Mike Kaganski |
1 user thanked mikekaganski for this useful post.
This issue related not only for X-Y Plot but for all regions which have placeholder. I would like to clarify that people are not confused. |
Originally Posted by: uni Nice trick uni , thank you It could have been done with bar graphs as well. I think there is no this type of graph implemented yet, neither in X-Yplot nor ZedGraph. Regards, Radovan |
Slightly off-topic, as no xy-plot involved... File Attachment(s): mkraska attached the following image(s): |
3 users thanked mkraska for this useful post.
on 01/06/2013(UTC), on 01/06/2013(UTC), on 02/06/2013(UTC)
Originally Posted by: mkraska Slightly off-topic, as no xy-plot involved... I think could be posted as a snippet, very nice stuff |
@Uni This .Net2.0 LGPL library could be useful for your plugin. Johns Hope's FPlotThe download includes the program as well as the library. It permorms plotting and fitting of measurement data and mathematical functions (Levenberg-Marquardt and Nelder & Mead fitting). It has nice interactive features (zoom and trace) and an interesting user interface.
3 users thanked kilele for this useful post.
on 03/06/2013(UTC), on 03/06/2013(UTC), on 03/06/2013(UTC)
Version 4906.20018 of XYPlot fails to install on my system (portable 4902). Error message says: plugin deactivated. Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. How can I do that? Edited by user 08 June 2013 01:31:17(UTC)
on 08/06/2013(UTC), on 08/06/2013(UTC)
Updated. Added support for scripts (for testing). chart2D.C2Points = `::Points` chart2D.C2XAxis.XLimMin = `::x.min` chart2D.C2XAxis.XLimMax = `::x.max` |
I use Iron Python. But the use of SciPy or NumPy is still a difficult task. |
Joined: 19/09/2009(UTC) Posts: 34 Was thanked: 17 time(s) in 11 post(s)
Hi
I'm trying to build your plugin XYPlotRegion with monodevelop 4.0 on ubuntu 13.04 and SMathStudio 0.96.4909
PluginRegion.cs:
public class PluginRegion : IPluginCustomRegion { PluginRegion.cs(18,18): Error CS0535: `XYPlotPlugin.PluginRegion' does not implement interface member `SMath.Control.IPluginCustomRegion.TagName.get' (CS0535) (XYPlotRegion)
I have the same error with 3DPlotRegion plugin
Do you know this error ? I'm not a specialist of C#.
Philippe DALET
FRANCE
Hi, Philippe! Yes, I know what the problem is. I think the sources are out of date. Unfortunately, I can't update it now. But you can solve this problem by adding few lines of code (use the latest dlls from SMath Studio: canvas.dll, ioman.dll, NuLib.dll and SyLib.dll). namespace XYPlotPlugin { public class PluginRegion : IPluginCustomRegion { #region Private fields string tagName = "xyplot"; AssemblyInfo[] dependences; MenuButton[] menuButtons; DragAndDropFileType[] dragAndDropFileTypes; #endregion #region Члены IPluginCustomRegion public string TagName {
get { return tagName; } }Edited by user 21 July 2013 15:54:20(UTC)
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: mkraska Slightly off-topic, as no xy-plot involved... To reduce the computation time of function fil2 can change the first line of the program Edited by user 21 September 2013 10:34:46(UTC)
1 user thanked Ber7 for this useful post.
Fridel, thanks for revisiting the snippet and the performance issue. Quite odd for me: The fastest way seems to be direct element adressing without pre-allocation and avoiding stack(). See attachment. The speed-up is significant. Please post any response to the new dedicated topicSnippet and examples are updated in the online gallery of the extension manager. Edited by user 21 September 2013 12:51:33(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
