see image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7 Edited by user 23 March 2014 14:06:06(UTC)
| Reason: Not specified mkraska attached the following image(s): |
Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: mkraska see image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7 I am using the same SMath version but Win XP SP3 and cannot duplicate the crash you describe. If I follow your steps a get (a+ != and depending upon if a and b would have been assigned values either an error a sof "a" being unknown or the correct numeric result.
1 user thanked rmix22 for this useful post.
Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b. after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash. mkraska attached the following image(s): |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
this is confirmed
best regards,
Davide |
Originally Posted by: mkraska Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash. Yes, I can confirm that bug now.
Bug seems to be fixed, cannot reproduce it any more in 0.97.5189. |
