In the last version of Smath, the plugin is not working any more
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
Originally Posted by: jurep In the last version of Smath, the plugin is not working any more Hello jurep, what kind of problem did you notice? Your Operating System? |
Hi! I get this message my system is win7
Seems that the file was saved using an old version of the plugin; meanwhile standards for plugins design was well defined, so a unique identifier (guid) was introduced for each plugin. It is easy to fix and you can do it by yourself. Please open your worksheet with a text editor (Windows' Notepad, Notepad++, etc...) Look at the headers of the XML code; you should see a block of code like this Code:<dependences>
<assembly name="SMath Studio Desktop" version="..." guid="a37cba83-b69c-4c71-9992-55ff666763bd" />
<assembly name="..." ... />
</dependences>
Also, you should see that the plugin has saved a null Guid Code:<assembly name="Custom Functions" version="..." guid="00000000-0000-0000-0000-000000000000" />
To solve the issue, replace the null guid of Custom Functions with the official guid Code:18dadffd-79a3-4cf9-aee1-d66deb0ea720
Let me know if this solve your issues Best regards, Davide Edited by user 20 August 2014 12:25:26(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Thanks for super fast replay! It works now! thanks again!
You're welcome |
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
Has sys2mat.1() been withdrawn or is this a bug? File Attachment(s): mkraska attached the following image(s): |
ops... I've lost the sources of that update, not uploaded in the SVN, so I've rebuilt the missing functions but seems that I've forget the function. I'll restore it on the next update. Edited by user 04 September 2014 16:00:12(UTC)
PLUGIN UPDATED- restored sys2mat.1 - Max()/Min() now returns itself when a variable is not defined ( SS-114) - Diag() accept systems as input ( SS-1248) Edited by user 02 December 2014 14:45:04(UTC)
| Reason: link fixed |
Hello, I found this extra functions today... great, I will especially use the Max and Min functions. Thank you very much Davide
sys2mat.1() again seems to be missing... |
works for me... what version of the plugin do you have? Edited by user 22 September 2015 11:16:26(UTC)
Originally Posted by: w3b5urf3r_reloaded works for me... what version of the plugin do you have? seems to be up to date. EDIT: The function is avaiable, but obviously there have been changes in handling text indices. I choose sys2mat.1() from the dynamic assistant but the .1 won't display as text index. Once I delete the dot and type it in again, then the text index appears and the function becomes undefined. Here is the system information:
SMath Studio: SMath Studio Desktop 0.97.5737.24521, portable, x64 OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Microsoft Windows 7 Professional , x64) Screen: 1920x1080 px, 96x96 dpi Localization: separator=<semicolon>; decimal symbol=<comma>; system decimal symbol=<period>; language=GER Frameworks: CLR 2.0.50727.5485
installed versions: v2.0.50727 2.0.50727.5420 SP2 v3.0 3.0.30729.5420 SP2 v3.5 3.5.30729.5420 SP1 v4 Client 4.5.50709 Full 4.5.50709 v4.0 Client 4.0.0.0
Edited by user 22 September 2015 12:06:35(UTC)
| Reason: Not specified mkraska attached the following image(s): |
on 22/09/2015(UTC), on 22/09/2015(UTC)
Found the bug, I'll update the plugin ASAP |
PLUGIN UPDATED
- fixed localization issues in sys2mat.1() (thanks to Martin Kraska) |
PLUGIN UPDATED SMath Studio 0.97.5346 and later and SMath Studio 0.97.5737- added Abs(1) (extends built-in abs(1) to matrices);
- added Conjugate(1);
- improved description of InterpBilinear(5);
- refactoring;
Edited by user 16 January 2016 18:47:01(UTC)
| Reason: added screenshot |
on 16/01/2016(UTC), on 16/01/2016(UTC)
Thank you Ioan, bug confirmed. I'll fix it ASAP. |
PLUGIN UPDATED SMath Studio 0.97.5737 and later
- Added var2str(1) and var2str(2) [customized versions of num2str for numerical display in 2D plots]; - Added functions from (ex) Functions' Extension: at, ternary booleans, cases, Kronecker, perc, permil; - Added clone of Ceil() & Floor() from Statistical Tools; - Added clone of Unknowns() from NonlinearSolvers; - Added glyph for Conjugate(); - Fixed issues of stack/augment in placeholders for Max() & Min(); - refactoring;
3 users thanked Davide Carpi for this useful post.
on 03/03/2016(UTC), on 03/03/2016(UTC), on 03/03/2016(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and SMath Studio 0.97.5737 and later- Max and Min reworked to use numerical engine (to fix this bug); |
