7 Pages<12345>»
Offline jurep
#41 Posted : 19 August 2014 12:26:39(UTC)
jurep
Slovenia
In the last version of Smath, the plugin is not working any more Sad
#42 Posted : 19 August 2014 13:25:12(UTC)
Was thanked: 1332 time(s) in 876 post(s)
Hello jurep, what kind of problem did you notice? Your Operating System?
Offline jurep
#43 Posted : 20 August 2014 11:43:37(UTC)
jurep
Slovenia
Hi!
I get this message
test
my system is win7
#44 Posted : 20 August 2014 12:14:54(UTC)
Seems that the file was saved using an old version of the plugin; meanwhile standards for plugins design was well defined, so a unique identifier (guid) was introduced for each plugin. It is easy to fix and you can do it by yourself.
Please open your worksheet with a text editor (Windows' Notepad, Notepad++, etc...)
Look at the headers of the XML code; you should see a block of code like this
Code:
<dependences>
      <assembly name="SMath Studio Desktop" version="..." guid="a37cba83-b69c-4c71-9992-55ff666763bd" />
      <assembly name="..." ... />
    </dependences>
Also, you should see that the plugin has saved a null Guid
Code:
<assembly name="Custom Functions" version="..." guid="00000000-0000-0000-0000-000000000000" />
To solve the issue, replace the null guid of Custom Functions with the official guid
Code:
18dadffd-79a3-4cf9-aee1-d66deb0ea720
Let me know if this solve your issues Good
Best regards,
Davide
Edited by user 20 August 2014 12:25:26(UTC)  | Reason: Not specified
Offline jurep
#45 Posted : 20 August 2014 12:35:50(UTC)
jurep
Slovenia
Thanks for super fast replay! It works now! thanks again!
#46 Posted : 20 August 2014 12:46:28(UTC)
You're welcome Good
#47 Posted : 04 September 2014 00:34:45(UTC)
Has sys2mat.1() been withdrawn or is this a bug?
File Attachment(s):
Section lists functions.sm (16kb) downloaded 59 time(s).
#48 Posted : 04 September 2014 15:25:42(UTC)
ops... Confusion
I've lost the sources of that update, not uploaded in the SVN, so I've rebuilt the missing functions but seems that I've forget the function. I'll restore it on the next update. Biggrin
Edited by user 04 September 2014 16:00:12(UTC)  | Reason: Not specified
#49 Posted : 02 December 2014 13:23:03(UTC)
PLUGIN UPDATED
- restored sys2mat.1
- Max()/Min() now returns itself when a variable is not defined (SS-114)
- Diag() accept systems as input (SS-1248)
Edited by user 02 December 2014 14:45:04(UTC)  | Reason: link fixed
on 02/12/2014(UTC)
Offline csb531
#50 Posted : 16 December 2014 14:02:40(UTC)
csb531
Rank: Member
Netherlands
I found this extra functions today... great, I will especially use the Max and Min functions.
Thank you very much Davide Good
#51 Posted : 22 September 2015 10:02:09(UTC)
sys2mat.1() again seems to be missing...
File Attachment(s):
sys2mat.1.sm (5kb) downloaded 59 time(s).
#52 Posted : 22 September 2015 11:11:36(UTC)
works for me... what version of the plugin do you have? Umnik
Edited by user 22 September 2015 11:16:26(UTC)  | Reason: Not specified
#53 Posted : 22 September 2015 11:51:39(UTC)
seems to be up to date.
EDIT: The function is avaiable, but obviously there have been changes in handling text indices. I choose sys2mat.1() from the dynamic assistant but the .1 won't display as text index. Once I delete the dot and type it in again, then the text index appears and the function becomes undefined.
Here is the system information:
Edited by user 22 September 2015 12:06:35(UTC)  | Reason: Not specified
on 22/09/2015(UTC),  on 22/09/2015(UTC)
#54 Posted : 22 September 2015 12:08:52(UTC)
Found the bug, I'll update the plugin ASAP
on 22/09/2015(UTC)
#55 Posted : 22 September 2015 12:40:10(UTC)
PLUGIN UPDATED
- fixed localization issues in sys2mat.1() (thanks to Martin Kraska)
on 22/09/2015(UTC)
#56 Posted : 16 January 2016 18:40:38(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and later and SMath Studio 0.97.5737
  • added Abs(1) (extends built-in abs(1) to matrices);
  • added Conjugate(1);
  • improved description of InterpBilinear(5);
  • refactoring;
2016-01-16 16_42_21-SMath Studio Desktop - [CustomFunctions_examples.sm].png
Edited by user 16 January 2016 18:47:01(UTC)  | Reason: added screenshot
on 16/01/2016(UTC),  on 16/01/2016(UTC)
#57 Posted : 19 January 2016 18:51:21(UTC)
Thank you Ioan, bug confirmed. I'll fix it ASAP.
on 19/01/2016(UTC)
#58 Posted : 19 January 2016 23:24:51(UTC)
Alternately if your stuff is in appropriate vector(s)
make it "Smath style"
Utilities Conjugate_Absolute.sm (12kb) downloaded 71 time(s).
#59 Posted : 03 March 2016 21:25:21(UTC)
PLUGIN UPDATED SMath Studio 0.97.5737 and later
- Added var2str(1) and var2str(2) [customized versions of num2str for numerical display in 2D plots];
- Added functions from (ex) Functions' Extension: at, ternary booleans, cases, Kronecker, perc, permil;
- Added clone of Ceil() & Floor() from Statistical Tools;
- Added clone of Unknowns() from NonlinearSolvers;
- Added glyph for Conjugate();
- Fixed issues of stack/augment in placeholders for Max() & Min();
- refactoring;
thanks 3 users thanked Davide Carpi for this useful post.
on 03/03/2016(UTC),  on 03/03/2016(UTC),  on 03/03/2016(UTC)
#60 Posted : 07 March 2016 15:09:06(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and SMath Studio 0.97.5737 and later
- Max and Min reworked to use numerical engine (to fix this bug);
Guest (2)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages<12345>»
