Offline Ernesto
#1 Posted : 04 September 2014 21:18:07(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
After updating to the new version, none of my "if" functions are working. I get the following error:
"Method not found: 'System.String Smath.Manager.UnitInfo.GetCurrentUnitName(System.String)'."
Anyone else have this issue?
File Attachment(s):
if_bug.sm (3kb) downloaded 17 time(s).
Ernesto attached the following image(s):
Offline Andrey Ivashov
#2 Posted : 05 September 2014 00:11:29(UTC)
Rank: Administration
Ernesto, looks like you have some outdated plug-ins. Please open Extensions Manager update installed plug-ins.
Regards.
Offline Ernesto
#3 Posted : 05 September 2014 00:53:26(UTC)
Ernesto
Nicaragua
The Extensions Manager only gives the option to enable or disable the plugins. I don't see how I could delete or update any of the plugins.
I even tried uninstalling and installing Smath Studio again, and the same error appears.
Edited by user 05 September 2014 00:55:10(UTC)  | Reason: Not specified
#4 Posted : 06 September 2014 20:33:42(UTC)
Ernesto, Extensions Manager allows to update plug-ins.
Please see attached image. Select Online gallery and see the list - available updates shown in violet.
Andrey Ivashov attached the following image(s):
Offline Ernesto
#5 Posted : 06 September 2014 21:49:25(UTC)
Ernesto
Nicaragua
It wouldn't update. I had to uninstall, as well as delete the \Users\[user name]\AppData\Roaming\SMath directory, then reinstall for it to work.
Everything is working now Good
