Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
After updating to the new version, none of my "if" functions are working. I get the following error: "Method not found: 'System.String Smath.Manager.UnitInfo.GetCurrentUnitName(System.String)'." Anyone else have this issue? File Attachment(s): Ernesto attached the following image(s):
Ernesto, looks like you have some outdated plug-ins. Please open Extensions Manager update installed plug-ins.
Regards.
The Extensions Manager only gives the option to enable or disable the plugins. I don't see how I could delete or update any of the plugins. I even tried uninstalling and installing Smath Studio again, and the same error appears. Edited by user 05 September 2014 00:55:10(UTC)
Ernesto, Extensions Manager allows to update plug-ins. Please see attached image. Select Online gallery and see the list - available updates shown in violet. Andrey Ivashov attached the following image(s):
It wouldn't update. I had to uninstall, as well as delete the \Users\[user name]\AppData\Roaming\SMath directory, then reinstall for it to work. Everything is working now
