27 Pages«<7891011>»
Offline RFreund
#161 Posted : 16 October 2013 05:40:39(UTC)
RFreund
United States
Where is the latest download for this plug-in? I did not see it in the registered plugins file.
Thanks!
Offline uni
#162 Posted : 16 October 2013 10:44:23(UTC)
uni
Russia ☭ forever
Viacheslav N. Mezentsev
#163 Posted : 25 October 2013 18:26:04(UTC)
If one of the plot objects fails to be evaluated, then the settings in the traces dialog are lost. This is particularly annoying, if this is just because of a temporary error in computing any of the objects.
on 25/10/2013(UTC)
#164 Posted : 08 December 2013 14:50:09(UTC)
When duplicating a plot by ctrl-drag, then the trace labels (seriesname) in the legend disappear.
File Attachment(s):
Griffith.sm (21kb) downloaded 72 time(s).
on 08/12/2013(UTC),  on 08/12/2013(UTC)
#165 Posted : 23 December 2013 14:43:52(UTC)
The legend shows line patterns even if line visibility is set to false for the data series.
Workaround: Set the line color to transparent (see left plot).
Uni, I think that the X-Y Plot plugin is definitely worth further maintenance, as it currently provides the best trade between usability and flexibility. The Maxima plugin might provide similar capabilities some day (there are severe issues with list and matrix translations) but I do not expect the regular user to have Maxima installed or to learn the graphic objects and options.
Important improvements would be:
- log options for the axes
- format dialog similar to Mathcad (avoids clicking through the object tree).
- separate mouse scaling of x and y axes just like in the built-in plot region
File Attachment(s):
Vergütungsstähle.sm (29kb) downloaded 84 time(s).
VERGUET.txt (5kb) downloaded 69 time(s).
thanks 3 users thanked mkraska for this useful post.
on 23/12/2013(UTC),  on 23/12/2013(UTC),  on 24/12/2013(UTC)
Offline uni
#166 Posted : 23 December 2013 15:15:09(UTC)
uni
I agree. I don't have time for revision of the plugin. I'm afraid to make changes, because then they will need to support. I don't have a complete picture of how the final version should look like.
We still don't have an agreed version of code to save the plugin settings. In this regard, the new version of the plugin may be incompatible with old documents. The code that I use to save the settings I don't like. Need to alter it so that maintained upward compatibility. This problem hinders the development of the plugin.
Russia ☭ forever
on 24/12/2013(UTC)
Offline uni
#167 Posted : 07 February 2014 15:40:44(UTC)
uni
Updated.
EDIT: Try again. There were problems with redrawing.
EDIT2: Unfortunately, I can't now fully upgrade the plugin. I used the old sources for updates (I'm in another area). The current version of the plugin is not stable. Therefore, have to wait until I get back.
Edited by user 07 February 2014 19:09:22(UTC)  | Reason: Not specified
Russia ☭ forever
on 07/02/2014(UTC),  on 07/02/2014(UTC),  on 07/02/2014(UTC)
Offline zorrykid
#168 Posted : 21 February 2014 11:41:16(UTC)
zorrykid
Rank: Member
Hi Uni
thanks a lot for your wonderful Estensions for SMath.
This message is just to inform you that there is a litte problem to draw single point in X-Y Plot despite 2D Plot.
Looks like are allowed only array with 2 colums ( see below ) and to draw single point are needed more.
Best Regard
Franco
zorrykid attached the following image(s):
thanks 1 user thanked zorrykid for this useful post.
on 21/02/2014(UTC)
Offline zorrykid
#169 Posted : 21 February 2014 15:22:39(UTC)
zorrykid
Rank: Member
Sorry Uni,
I have checked better and have seen that with the X-Y Plot is possible to draw a single point not using the same method used for the Plot 2D Area.
So this need is addressed.
Franco
on 21/02/2014(UTC)
Offline zorrykid
#170 Posted : 24 February 2014 16:10:48(UTC)
zorrykid
Rank: Member
There is something strange in the X-Y Plot too..a file of mine that worked fine in the previous portable release doesn't work now if one of the curve is a costant ( an orizontal line ).
Very strange.
Franco
thanks 2 users thanked zorrykid for this useful post.
on 05/09/2014(UTC),  on 17/11/2018(UTC)
Offline 1andro1
#171 Posted : 03 September 2014 00:21:45(UTC)
1andro1
Bulgaria
Hi Uni,
Thank you very much for the nice plugin.
I would like to ask you whether there is a chance the limit of the axes (XLimMin, XLimMax, XTick, YLimMin, YlimMax and YTick) to be made to be updated from the worksheet of the Smath?
As example if I have a variable in the worksheet which to calculates my Xmin and Xmax limits to be able to enter the name of that variable in the fields for XLimMin and XLimMax.
Also it would be nice feature if it is possible, after some digits, the tick number to become with scientific notation. As example if I have a value between 10uA and 100uA and I want a tick in every 10uA, currently, X-Y plot will show it as 0.
Best Regards,
Adriyan
Offline uni
#172 Posted : 05 September 2014 16:24:56(UTC)
uni
Originally Posted by: 1andro1 Go to Quoted Post
Hi Uni,
Best Regards,
Adriyan
Some of these things already exist but other need to be realized, I agree.
uni attached the following image(s):
Russia ☭ forever
on 05/09/2014(UTC),  on 05/09/2014(UTC),  on 13/05/2015(UTC)
Offline 1andro1
#173 Posted : 06 September 2014 00:02:49(UTC)
1andro1
Bulgaria
Hi Uni,
Thank you very much for the hints. Indeed, all which I require is already included in the package. My apologies that I have not seen all these features.
Once more thank you very much for the nice package and for the help.
Best Regards,
Adriyan
Offline cmmcnamara
#174 Posted : 11 May 2015 22:33:04(UTC)
cmmcnamara
United States
Hi uni,
Thanks for your awesome plugin, it has helped me greatly with using SMath to visualize lots of data.Clap
Is there currently a way to have a sheet control which can change the title and labels? Also is it possible to control the ticks and numbers on the Y2 axis? Currently it appears that using "XYPlot.Y2Tick" does not work.
Offline ndtma
#175 Posted : 13 May 2015 10:10:32(UTC)
ndtma
Sri Lanka
Hi All
I have noticed a strange behaviour in XY-Plot.
1. In a sm file there are 2 different plots (with index 1 & index 2) working as expected.
2. When the file is saved and reloaded, the 2nd plot re-adjusts to index 1, showing a distorted view.
Where have I gone wrong please? (sm file attached).
ndtma
File Attachment(s):
Test XY Plot.sm (293kb) downloaded 77 time(s).
Offline uni
#176 Posted : 13 May 2015 11:34:00(UTC)
uni
I'm a little busy , I will look later.
Russia ☭ forever
on 14/05/2015(UTC)
Offline b3nd3r
#177 Posted : 01 September 2015 20:46:28(UTC)
b3nd3r
On recommendation of w3b5urf3r_reloaded I wanted to use your pluging. But with the current build 5346 of version 0.97 date 21.08.2014 the plugin a unknown error occurs if the plugin is loaded.
Is this a known bug? Which kind of further information do you need?
Offline uni
#178 Posted : 07 September 2015 07:49:18(UTC)
uni
Plugin not updated for new version. I'll try to fix this.
Russia ☭ forever
Offline ndtma
#179 Posted : 07 October 2015 06:42:29(UTC)
ndtma
Sri Lanka
Hi
I too reported to this forum, about 5 months ago, about the problem of saving X-Y Plot settings.
thanks 2 users thanked ndtma for this useful post.
on 07/10/2015(UTC),  on 07/10/2015(UTC)
Offline uni
#180 Posted : 07 October 2015 09:33:50(UTC)
uni
Originally Posted by: ndtma Go to Quoted Post
Hi
Updated. Fixed. Empty title now supported.
Quote:
Please, is there available the access by program to some other parameters as Traces colors and thinnesses ?
On the other side, I've seen that the plugin generate a system crash if wrong data. Please, could it be possible to include in the plugin a programming sequence of the type "ON ERROR GO NEXT" ?
I'll think about it. I must know what kind of wrong data you want to skip.
Edited by user 07 October 2015 09:37:25(UTC)  | Reason: Not specified
Russia ☭ forever
on 07/10/2015(UTC),  on 07/10/2015(UTC),  on 07/10/2015(UTC)
Guest (4)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
27 Pages«<7891011>»
