#1 Posted : 16 April 2016 15:29:14(UTC)
As long as they both reside in the same working directory.
Download both work sheets, open only the "Genfit Algo Include Test".
The plot is there in < 1 sec. More genfit models are expected.
At any point in a work sheet, same topo to read more user algos.
Genfit Algo Include.sm (14kb) downloaded 44 time(s).
Genfit Algo Include Test.sm (17kb) downloaded 41 time(s).
on 16/04/2016(UTC)
Offline mikekaganski
#2 Posted : 16 April 2016 15:38:34(UTC)
mikekaganski
Everything works great, if you remove "C:\" from include - otherwise it doesn't look at the same directory, but directly at c:\.
Best regards,
Mike Kaganski
Offline ElSid
#3 Posted : 18 April 2016 16:04:01(UTC)
ElSid
United States
Originally Posted by: уни Go to Quoted Post
βNlin() redefined (βNlin() := include() = 4).
Light bulb went off with this comment
I think these would be cleaner Jean. You can put it in any directory.
Genfit Algo Include Test.sm (20kb) downloaded 41 time(s).The directory change in this one is the critical one if I understand it correctly.
Genfit Algo Include.sm (15kb) downloaded 40 time(s).
#4 Posted : 18 April 2016 20:05:10(UTC)
Sure you can put it in any directory, I have only one C: for reasons of hyperfunctionality.
Why should I need zillions of directories if one is enough. Smath is not like rabbits and
wolfes in the same barn. Afer all, Santa has only one carriage.
Offline ElSid
#5 Posted : 18 April 2016 21:27:03(UTC)
ElSid
United States
My files are set up by projects.
Edited by user 19 April 2016 15:55:31(UTC)  | Reason: Not specified
Guest (2)
Similar Topics
include files @ startup (Questions)
by charlamb 10/05/2023 23:44:05(UTC)
Adidas include guaranteed with the 12 months (Bugs & Problems)
by Guest 11/12/2020 07:02:55(UTC)
include function issues (Questions)
by jrufener 01/06/2019 21:44:47(UTC)
[include plugin] missing LinqBridge.dll error in SMath Viewer executables (Bugs & Problems)
by resist 24/11/2017 18:07:37(UTC)
Include and Combobox Region (Questions)
by RFreund 01/03/2016 02:18:21(UTC)
Include function (Feature Requests)
by LordMike 24/10/2009 05:15:45(UTC)
