Offline uncblue
#1 Posted : 27 July 2016 00:06:01(UTC)
uncblue
Rank: Member
United States
Was thanked: 2 time(s) in 2 post(s)
I'm trying to recreate a mathcad calculation in smath and I'm not sure how to make the evaluation "l" which is the resultant distance for each point.
Thanks in advance for any help.
C' Bolt Coefficient.sm (10kb) downloaded 29 time(s).
DownloadDocumentFile.pdf (9kb) downloaded 45 time(s).
Offline Ernesto
#2 Posted : 27 July 2016 02:02:04(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
Here you go. There might be another way to do this, but this was the first I thought of.
C' Bolt Coefficient revised.sm (12kb) downloaded 33 time(s).
#3 Posted : 27 July 2016 04:55:28(UTC)
Is that the bolt group ? If so: what else to do ?
Offline uncblue
#4 Posted : 27 July 2016 17:20:59(UTC)
uncblue
Rank: Member
United States
Thanks Ernesto.
@Jean
The next step is to use the C' equation to for each bolt resultant distance to center of group.
I think I've got the C' equation working but I'm sure there is a better way.
C' Bolt Coefficient - 2016-07-27.sm (34kb) downloaded 18 time(s).
Edited by user 27 July 2016 17:28:41(UTC)  | Reason: Not specified
Offline uncblue
#5 Posted : 27 July 2016 18:17:10(UTC)
uncblue
Rank: Member
United States
"Uncle Sam",
By inspetion, I kind of understand the C' formula,
just a matter to code Smath. Will be back tonight.
What is Δmax ?
Thanks for the help.
Δmax = Maximum deformation on the bolt farthest from the center of gravity.
Empirical set value = 0.34 in
Offline CBG
#6 Posted : 27 July 2016 18:52:08(UTC)
CBG
you can use the same formula
C' Bolt Coefficient_CBG.sm (14kb) downloaded 22 time(s).
thanks 1 user thanked CBG for this useful post.
on 29/07/2016(UTC)
