![Andrey Ivashov Andrey Ivashov](/forum/resource.ashx?u=4) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,636 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Was thanked: 2007 time(s) in 677 post(s)
SMath Studio 0.98.6075 available - SS-2368: Units don't match issue fixed happened in several cases for numeric calculation;
- SS-2366: Showing of Reference Book and Print Preview windows when SMath Studio shown always on top fixed;
- Plot Region improved for better support of animated graphs created in previous versions of the program;
- Fixed issues with repeated worksheet evaluation started automatically without any user request (usually happened on complex worksheet open or on complex expression paste);
- Symbolic engine: Infinity divided by zero is equal to Infinity now (the same as done for Numeric engine);
- Location of breakpoints corrected on vertical scrollbar when breakpoint(s) set on operands;
- Displaying current stop when calculation paused corrected when stop is on operand;
- Empty Missing Plugins dialog appeared sometimes on file open fixed;
- Meaningless message of Missing Plugins dialog about incorrect version of built-in plugins (MathRegion and AreaRegion) on file open removed;
- Handling of remove Region operation improved (worksheet recalculated if content of focused MathRegion deleted using Backspace);
- Paste of math expression (not a MathRegion itself) from Clipboard do not initiate immediate worksheet recalculation anymore;
- Shortcut key added to Toggle Breakpoint context menu item;
![ctrlf8.png](/forum/resource.ashx?a=14478&b=2)
- Interface translation files updated;
- Refactoring.
Download Edited by user 20 August 2016 10:45:13(UTC)
![thanks](/forum/Themes/yafvision/heart_small.png) 5 users thanked Andrey Ivashov for this useful post.
on 19/08/2016(UTC), on 19/08/2016(UTC), on 19/08/2016(UTC), on 19/08/2016(UTC), on 19/08/2016(UTC)
![RFreund RFreund](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 25/09/2013(UTC) Posts: 330 ![United States United States](/forum/Content/images/flags/US.png) Location: IL Was thanked: 19 time(s) in 17 post(s)
What does this refer to: "Shortcut key added to Toggle Breakpoint context menu item"
Thanks!
Originally Posted by: RFreund ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) What does this refer to: "Shortcut key added to Toggle Breakpoint context menu item" Sure. Screenshot added above. Best regards.
Thank you. One other thing I've noticed. When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
You're welcome. Originally Posted by: RFreund ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change? Nope, seems I just forgot about this behavior during MathRegion code review. Will check it, thank you.
![thanks](/forum/Themes/yafvision/heart_small.png) 1 user thanked Andrey Ivashov for this useful post.
![mikekaganski mikekaganski](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 17/01/2013(UTC) Posts: 296 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Could it be possible then to go to units placeholder immediately when one inserts equal? What's the reason to stay before it? |
Best regards, Mike Kaganski |
![thanks](/forum/Themes/yafvision/heart_small.png) 3 users thanked mikekaganski for this useful post.
on 20/08/2016(UTC), on 20/08/2016(UTC), on 21/08/2016(UTC)
