SMath Studio Forum
Download SMath Studio
Archive
RC4: SMath Studio 0.98.6103 (16 September 2016)
![Andrey Ivashov Andrey Ivashov](/forum/resource.ashx?u=4) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,636 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Was thanked: 2007 time(s) in 677 post(s)
Release Candidate: SMath Studio 0.98.6103 available - Critical stack overflow exceptions which may appear f.e. because of dead loops in definitions fixed;
- SS-2405: Expressions drawing issues on print out in case of non-standard DPI fixed;
- Handling of sum(..) function corrected to improve back-compatibility;
- Fixed multiple issues with not refreshed Regions (in different cases: on Region focused, on collapsed Area text changing and in some cases on click into Region located after collapsed Area);
- Handling of TAB/Shift+TAB keyboard buttons improved to take into account invisible Regions and current cursor position on the Worksheet;
- Fixed issue appears for some third-party regions when calling for context menu;
- Warnings about usage of time(..) and random(..) functions implemented for worksheet testing in silent mode;
- Refactoring.
Download
![thanks](/forum/Themes/yafvision/heart_small.png) 7 users thanked Andrey Ivashov for this useful post.
on 16/09/2016(UTC), on 16/09/2016(UTC), on 16/09/2016(UTC), on 16/09/2016(UTC), on 17/09/2016(UTC), on 17/09/2016(UTC), on 17/09/2016(UTC)
Most likely it is a latest release candidate prepared before new stable release. I expect no any significant changes will be done since today to be sure next build will be stable and tested enough.
Best regards, Andrey Ivashov.
![pavel_n pavel_n](/forum/resource.ashx?url=http%3a%2f%2fen.smath.info%2fforum%2fUploads%2f13545.jpg&width=100&height=100) Rank: Newbie
Joined: 29/09/2016(UTC) Posts: 2 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Location: Красноярск Was thanked: 4 time(s) in 2 post(s)
In the last versions of SMath Studio last value of range(3) is lost in most cases: Presumably, range(3) works correctly if the first value = 1, or the step = 0,5 or 1: range(1, 3, 1.2), range(2, 4, 2.5), range(2, 6, 3) In other cases it behaves not like range [a;b] but like interval [a;b ) : range(2, 4, 2.2), range(1, 2, 1.1) ![](/forum/resource.ashx?imgprv=1445) Edited by user 29 September 2016 05:12:20(UTC)
![thanks](/forum/Themes/yafvision/heart_small.png) 2 users thanked pavel_n for this useful post.
on 29/09/2016(UTC), on 30/09/2016(UTC)
![Davide Carpi Davide Carpi](/forum/resource.ashx?u=1544) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,725 ![Man Man](/forum/Themes/yafvision/male.gif) ![Italy Italy](/forum/Content/images/flags/IT.png) Location: Italy Was thanked: 1393 time(s) in 909 post(s)
Thank you
pavel_n
seems there is really a bug Andrey has fixed it, change will be available in the next relase ![Good](/forum/Images/Emoticons/sm_smile_good.gif) Edited by user 29 September 2016 15:03:15(UTC)
SMath Studio Forum
Archive
