Offline Andrey Ivashov
#1 Posted : 16 September 2016 19:09:14(UTC)
Rank: Administration
Was thanked: 2007 time(s) in 677 post(s)
Release Candidate: SMath Studio 0.98.6103 available
Latest changes (against SMath Studio 0.98.6096)
  • Critical stack overflow exceptions which may appear f.e. because of dead loops in definitions fixed;
  • SS-2405: Expressions drawing issues on print out in case of non-standard DPI fixed;
  • Handling of sum(..) function corrected to improve back-compatibility;
  • Fixed multiple issues with not refreshed Regions (in different cases: on Region focused, on collapsed Area text changing and in some cases on click into Region located after collapsed Area);
  • Handling of TAB/Shift+TAB keyboard buttons improved to take into account invisible Regions and current cursor position on the Worksheet;
  • Fixed issue appears for some third-party regions when calling for context menu;
  • Warnings about usage of time(..) and random(..) functions implemented for worksheet testing in silent mode;
  • Refactoring.
Download
thanks 7 users thanked Andrey Ivashov for this useful post.
on 16/09/2016(UTC),  on 16/09/2016(UTC),  on 16/09/2016(UTC),  on 16/09/2016(UTC),  on 17/09/2016(UTC),  on 17/09/2016(UTC),  on 17/09/2016(UTC)
#2 Posted : 16 September 2016 19:25:22(UTC)
Most likely it is a latest release candidate prepared before new stable release. I expect no any significant changes will be done since today to be sure next build will be stable and tested enough.
Best regards, Andrey Ivashov.
Offline pavel_n
#3 Posted : 29 September 2016 05:00:10(UTC)
pavel_n
Was thanked: 4 time(s) in 2 post(s)
In the last versions of SMath Studio last value of range(3) is lost in most cases:
Presumably, range(3) works correctly if the first value = 1, or the step = 0,5 or 1:
range(1, 3, 1.2), range(2, 4, 2.5), range(2, 6, 3)
In other cases it behaves not like range [a;b] but like interval [a;b ) :
range(2, 4, 2.2), range(1, 2, 1.1)
Edited by user 29 September 2016 05:12:20(UTC)  | Reason: Not specified
thanks 2 users thanked pavel_n for this useful post.
on 29/09/2016(UTC),  on 30/09/2016(UTC)
#4 Posted : 29 September 2016 12:09:43(UTC)
Was thanked: 1393 time(s) in 909 post(s)
Thank you pavel_n Offline seems there is really a bug
Andrey has fixed it, change will be available in the next relase Good
Edited by user 29 September 2016 15:03:15(UTC)  | Reason: Not specified
