SMath Studio Forum
Questions
Help solving an equation iteratively
I have the equation 0.005*N^-0.12 + 0.565*N^-0.46 = 0.010 that I am trying to solve for N. I know the answer is ~9500 but I do not know how to solve it using SMath Studio. I tried "solve" but I get the "No real roots" error.
Originally Posted by: drewbagel423 I have the equation 0.005*N^-0.12 0.565*N^-0.46 = 0.010 that I am trying to solve for N. I know the answer is ~9500 but I do not know how to solve it using SMath Studio. I tried "solve" but I get the "No real roots" error. As simple as that: plot first to check if there is intersection between the two functions. You don't solve for a constant, you solve for a constant defined as a function. Next, guesstimate for bracketing the solve block ... done. Cheers collab.
... your project from iterative Dichotomy Solve Dichotomy.sm (10kb) downloaded 29 time(s).
Originally Posted by: Jean Giraud Originally Posted by: drewbagel423 I have the equation 0.005*N^-0.12 0.565*N^-0.46 = 0.010 that I am trying to solve for N. I know the answer is ~9500 but I do not know how to solve it using SMath Studio. I tried "solve" but I get the "No real roots" error. As simple as that: plot first to check if there is intersection between the two functions. You don't solve for a constant, you solve for a constant defined as a function. Next, guesstimate for bracketing the solve block ... done. Cheers collab. Works perfectly. Thanks!
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Originally Posted by: drewbagel423 I tried "solve" but I get the "No real roots" error. probably you have used solve(2) (function with 2 arguments) that is driven by the global parameters (tools > options > calculation > roots (range)) and is designed mainly for solutions on the fly. use instead solve(4), giving an adequate range (f.e. by plotting the function, as mentioned above by Jean) |
SMath Studio Forum
Questions
