Offline drewbagel423
#1 Posted : 08 September 2017 16:26:49(UTC)
drewbagel423
United States
I have the equation 0.005*N^-0.12 + 0.565*N^-0.46 = 0.010 that I am trying to solve for N. I know the answer is ~9500 but I do not know how to solve it using SMath Studio. I tried "solve" but I get the "No real roots" error.
#2 Posted : 08 September 2017 17:27:51(UTC)
Originally Posted by: drewbagel423 Go to Quoted Post
I have the equation 0.005*N^-0.12 0.565*N^-0.46 = 0.010 that I am trying to solve for N. I know the answer is ~9500 but I do not know how to solve it using SMath Studio. I tried "solve" but I get the "No real roots" error.
As simple as that: plot first to check if there is intersection
between the two functions. You don't solve for a constant, you
solve for a constant defined as a function. Next, guesstimate
for bracketing the solve block ... done.
Cheers collab.
#3 Posted : 08 September 2017 18:04:08(UTC)
... your project from iterative Dichotomy
Solve Dichotomy.sm (10kb) downloaded 29 time(s).
#4 Posted : 08 September 2017 18:27:18(UTC)
drewbagel423
United States
Cheers collab.
Works perfectly. Thanks!
#5 Posted : 08 September 2017 20:33:46(UTC)
probably you have used solve(2) (function with 2 arguments) that is driven by the global parameters (tools > options > calculation > roots (range)) and is designed mainly for solutions on the fly.
use instead solve(4), giving an adequate range (f.e. by plotting the function, as mentioned above by Jean)
