Offline MagneO
#1 Posted : 12 November 2017 18:50:22(UTC)
MagneO
Norway
I am new user of Smath and in order to teach myself a bit about this software I am trying make a simple calculation in degrees. However, I cannot find degrees? I cannot find Angle in the insert meny at all? What am I doing wrong?
Best Regards, Magne
Offline PompelmoTell
#2 Posted : 12 November 2017 19:18:16(UTC)
PompelmoTell
you can use
Insert -> Unit -> select "degree"
or shortcut ' -> select "°"
Offline MagneO
#3 Posted : 12 November 2017 19:21:08(UTC)
MagneO
Norway
Sorry my question was inaccurate, degrees as 360 per whole circle not radians.
Thanks for the quick reply anyway!
Magne
Offline MagneO
#4 Posted : 12 November 2017 19:27:19(UTC)
MagneO
Norway
Sorry my bad!
I misunderstood the callout, it IS ordinary degrees!
Thanks and regards, Magne
#5 Posted : 12 November 2017 21:03:03(UTC)
2/3=38.1972°
#6 Posted : 13 November 2017 04:12:08(UTC)
Offline MagneO
#7 Posted : 13 November 2017 10:09:22(UTC)
MagneO
Norway
Thank you!
This is exactly what I am unable to do! How do I make the trigonometric function return degrees?
Do I simply type the unit after the result? ( I am sorry if these questions are really daft!?)
Magne
#8 Posted : 13 November 2017 12:50:48(UTC)
All numerical functions are approximations in computing machinery.
Trigonometric function are in radian. If you want result in °
1. click on the empty place holder of the result,
2. click on the unit drop down menu from the tool bar,
3. click on ° or deg ... scroll down for 'rad' if you want result in radian.
on 09/10/2018(UTC)
Offline MagneO
#9 Posted : 13 November 2017 13:35:20(UTC)
MagneO
Norway
Thank you very much! Now I can make it work. I thought I had tried this but I probably used the input "position" wrong, I believe I simply typed it at the wrong place.
Thank you again, this is great forum!
Regards, Magne
