SMath Studio Forum
Questions
Thermal Physics - Rod in Cylinder
Joined: 29/11/2017(UTC) Posts: 82 Location: Midwest Was thanked: 9 time(s) in 7 post(s)
Originally Posted by: CBG This can be one of the solutions. The "T" in the formula can be easily isolated. Well done Carlos, I think it can be plotted directly on the canvas Will try tomorrow [tonight, I'm dead... not completely !] Jean
Originally Posted by: Jean Giraud I think it can be plotted directly on the canvas Will try tomorrow roots(,,) solve on the canvas. Next matter is the unit system to be adapted, unfortunately incompetent on that !
Not nearly as nice as your Mathcad sheet... Uses the symbolic solver in Maxima. You have to select one of the four solutions, I guess the real positive one is correct. Thermal%20Physics%20-%20Rod%20in%20Cylinder_Kr.sm (40kb) downloaded 23 time(s). |
on 31/01/2018(UTC), on 31/01/2018(UTC)
Thank you, all, for your help. I'll look closer at the solutions presented; learning more about SMATH.
Martin, I get a message opening your sheet looking for "Maxima.bat". Is this in a plugin that I need to download? Your sheet presents the following message: "Initializing error. Please reinitialize under settigs."
Norm
Please follow the link in my signature, there you find instructions how to install Maxima (a free CAS system) and how to tell SMath where to find it. |
Try this in stricly Smath ... done 6179. Very interesting, but missing the physical drawing !!! Solve Maple Thermal Physics.sm (34kb) downloaded 23 time(s).
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi. In the attached, just numerical methods, and how to parametrize the solver, like Mathcad find solve blocks. Best regards. Alvaro. Thermal Physics - Rod in Cylinder.sm (18kb) downloaded 27 time(s).
Carlos, Jean, Martin and Alvaro, many thanks! Your support is superb!
There's a lot here for me to digest.
Norm
Originally Posted by: nasch Carlos, Jean, Martin and Alvaro, many thanks! Your support is superb!
Norm Norm, observe closely your function ... it has rational format. It suggests that a rational model would fit the data set. Isn't true looking at the fit from a 4 terms rational. The red and green traces from Carlos would be as easy, not done. Please, don't forget the physical drawing. You could do the very same in Mathcad. Jean Maths Thermal Physics - Rod in Cylinder_R2.sm (67kb) downloaded 22 time(s).
Yet another one without using for-loops and using both [Built-in Plot] and [X-Y Plot Plugin]. God I really don't like to look at those for-loops, thanks to Andrey I will avoid them as much as I can. (Smath Studio 0.98.6604) Thermal Physics - Rod in Cylinder_R3.sm (21kb) downloaded 26 time(s).
Originally Posted by: overlord God I really don't like to look at those for-loops, thanks to Andrey I will avoid them as much as I can. Not backward compatible ... maybe a bug ? I welcomed that feature as it was announced. And reattached Mandelbroth, no answer from Designers ... maybe not so gorgeous as you pretend.
Originally Posted by: Razonar As I say before, this is a general numeric setup. Alvaro, Your original [previous] is a gorgeous piece of work. Just needed be doctored a bit. It might be compacted. Jean Maths Thermal Physics - Rod in Cylinder_R2 [Alvaro].sm (21kb) downloaded 27 time(s).
Originally Posted by: Jean Giraud Originally Posted by: overlord God I really don't like to look at those for-loops, thanks to Andrey I will avoid them as much as I can. Not backward compatible ... maybe a bug ? I welcomed that feature as it was announced. And reattached Mandelbroth, no answer from Designers ... maybe not so gorgeous as you pretend. It shouldn't work before 6580, using range like this is introduced with this verison as far as I remember. This is why I have written the Smath version I used. Anyway, below you can see how it looks. Still I think it looks better then for-loops. Regards
Hi Jean.
The point about MAXITERS is to figure after the root function body, not before in such way that you can change it like TOL in Mathcad.
Also notice that in your worksheet you don't call the function Bisection defined there, but the function Bisection from the Nonlinear solvers plugin.
Hello, Sooner or later, this way or another - one will end up by using some nonlinear solvers. Regards, Radovan Edited by user 01 February 2018 10:47:46(UTC)
Originally Posted by: overlord It shouldn't work before 6580, using range like this is introduced with this verison as far as I remember. This is why I have written the Smath version I used. Anyway, below you can see how it looks. Still I think it looks better then for-loops. I love for-loops ! 1. with units => "Matrix must be square" 2. w/o units => "Can not calculate"
SMath Studio Forum
Questions
