Hi. An uneval ability, like 'x' and x::uneval in maple, or Mathematica's Hold . Thanks for this wonderful tool that is SMath. Best regards.
SMath doesn't have a discrete uneval function of which I am aware. However, you can replicate that functionality depending on when you define the variables. Look at my example below. uneval.sm (4kb) downloaded 40 time(s). |
Hi. Thanks for the tip. But isn't enough for somethings more or less basics tasks, like call NDiff with 2 args, and not 3. Also, there are something else wrong about diff and how it handle some cases. Best regards. Alvaro. uneval.sm (9kb) downloaded 25 time(s).
Originally Posted by: alyles SMath doesn't have a discrete uneval function of which I am aware Isn't what Clear(,) does ? I Have an application example somewhere in Fourier compendium. To imitate Mathcad/Maple: make the variables wild.
Quote:Isn't what Clear(,) does ? Clear is more permament. The uneval function allows you re-enable without redefining the variable. |
Originally Posted by: Razonar Hi. Thanks for the tip. But isn't enough for somethings more or less basics tasks, like call NDiff with 2 args, and not 3. Also, there are something else wrong about diff and how it handle some cases.
Alvaro. The problem with your two argument function is that you're using hold() and value() functions in function call and those functions aren't defined anywhere. The method still works with your defined functions IFF you define a and b when you would normally call eval() You could also use the method Jean suggests, by calling . Only you would then have to redefine a and b when you want to evaluate. uneval (3).sm (11kb) downloaded 25 time(s).Edited by user 02 February 2018 21:49:22(UTC)
Originally Posted by: alyles Clear is more permament. The uneval function allows you re-enable without redefining the variable. Just disable Clear(,) to reuse same parameters. More generally if you "Clear" you want to redefine anyway, isn't ?
Originally Posted by: alyles The problem with your two argument function is that you're using hold() and value() functions in function call and those functions aren't defined anywhere. uneval (3).sm (11kb) downloaded 25 time(s). Sure, I'm requesting them. Originally Posted by: alyles You could also use the method Jean suggests, by calling ...
Jean's method is close, but not enough (actually it's equivalent to x='x' in the image). Can you replicate this Maple's code in SMath? Best regards. Alvaro.
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
Originally Posted by: Razonar Hi. Thanks for the tip. But isn't enough for somethings more or less basics tasks, like call NDiff with 2 args, and not 3. Isn't this pretty much what you want? Magics of the line operator. uneval_Kr.sm (9kb) downloaded 35 time(s).I forgot this one: Edited by user 02 February 2018 23:31:37(UTC)
Martin, Are the lines even necessary? What are they doing in your example? I see no difference in not using lines. |
Originally Posted by: alyles Thanks Martin!
I learned something new today. Looking forward to trying some more of these tricks with line operators in my own applications. I wish I could explain this. The debugger doesn't seem to reveal the secret: |
on 03/02/2018(UTC), on 03/02/2018(UTC)
I'm impressed! Excelent! Thanks, don't know what actues as hold but there are something there ... Now, my point is look if it can be done for external libraries, like coolprop or airy functions. And redefine diff for those cases where it fails. Best regards. Alvaro. Edited by user 03 February 2018 03:11:52(UTC)
Oops. Integers vs rationals.
Originally Posted by: mkraska I wish I could explain this. The line is a local definition operator. Observe the red example: coefficients 'a' exist/defined/assigned thus satisfy the Σ . On the other example |Σ 'c' result from calculations. The summing operator must "steal" the 'c' via the isolating local line operator. Differently but of same nature, DeBoor is redefined locally on the RHS. More examples have been encountered [there was Legendre polynomials...]
Hi. The proposed method looks excellent, but only works for integers. So, it's a bug or what else? Best regards. Alvaro
Originally Posted by: Razonar Hi. The proposed method looks excellent, but only works for integers. So, it's a bug or what else?
The at() function used for applying the perturbation makes a search and replace without limiting the search expression to valid variable names. It can't, however, handle expressions as replacement targets. The line function isn't at stake here. |
Originally Posted by: mkraska I learned something new today. Looking forward to trying some more of these tricks with line operators in my own applications. More generally, the line operator is the program operator. It may be as short as one element. Attached are three typical applications. DeBoor is just demo, here [attached separately]. Maths Local Definition.sm (29kb) downloaded 34 time(s). Spline De Boor [Colibri].sm (34kb) downloaded 32 time(s).
Maybe I don't understand what you are attempting, if so => here is simple procedure that needs no Uneval/re-eavl ... it just works on demand , wherever demanded in the work sheet. Maths Uneval.sm (8kb) downloaded 28 time(s).
