Offline Razonar
#1 Posted : 02 February 2018 09:38:26(UTC)
Razonar
Uruguay
Hi.
An uneval ability, like 'x' and x::uneval in maple, or Mathematica's Hold .
Thanks for this wonderful tool that is SMath.
Offline alyles
#2 Posted : 02 February 2018 16:53:23(UTC)
alyles
United States
SMath doesn't have a discrete uneval function of which I am aware. However, you can replicate that functionality depending on when you define the variables. Look at my example below. uneval.sm (4kb) downloaded 40 time(s).
Offline Razonar
#3 Posted : 02 February 2018 19:00:04(UTC)
Razonar
Uruguay
Hi. Thanks for the tip. But isn't enough for somethings more or less basics tasks, like call NDiff with 2 args, and not 3. Also, there are something else wrong about diff and how it handle some cases.
uneval.sm (9kb) downloaded 25 time(s).
#4 Posted : 02 February 2018 20:34:20(UTC)
Isn't what Clear(,) does ?
I Have an application example somewhere in Fourier compendium.
To imitate Mathcad/Maple: make the variables wild.
#5 Posted : 02 February 2018 20:52:16(UTC)
Maths Symbolic Export wrt Parameters.sm (9kb) downloaded 26 time(s).
Offline alyles
#6 Posted : 02 February 2018 21:08:46(UTC)
alyles
United States
Clear is more permament. The uneval function allows you re-enable without redefining the variable.
Offline alyles
#7 Posted : 02 February 2018 21:47:34(UTC)
alyles
United States
The problem with your two argument function is that you're using hold() and value() functions in function call and those functions aren't defined anywhere.
The method still works with your defined functions IFF you define a and b when you would normally call eval()
You could also use the method Jean suggests, by calling
Code:
clear(a,b)
. Only you would then have to redefine a and b when you want to evaluate.
uneval (3).sm (11kb) downloaded 25 time(s).
Edited by user 02 February 2018 21:49:22(UTC)  | Reason: Not specified
#8 Posted : 02 February 2018 22:31:50(UTC)
Just disable Clear(,) to reuse same parameters.
More generally if you "Clear" you want to redefine anyway, isn't ?
Offline Razonar
#9 Posted : 02 February 2018 22:57:26(UTC)
Razonar
Uruguay
Sure, I'm requesting them.
You could also use the method Jean suggests, by calling ...
Jean's method is close, but not enough (actually it's equivalent to x='x' in the image). Can you replicate this Maple's code in SMath?
#10 Posted : 02 February 2018 23:23:24(UTC)
Isn't this pretty much what you want? Magics of the line operator.
uneval_Kr.sm (9kb) downloaded 35 time(s).
I forgot this one:
Edited by user 02 February 2018 23:31:37(UTC)  | Reason: Not specified
on 02/02/2018(UTC)
Offline alyles
#11 Posted : 02 February 2018 23:57:16(UTC)
alyles
United States
Martin,
Are the lines even necessary? What are they doing in your example? I see no difference in not using lines.
#12 Posted : 03 February 2018 00:03:17(UTC)
Thanks Martin!
I learned something new today. Looking forward to trying some more of these tricks with line operators in my own applications.
I wish I could explain this.
The debugger doesn't seem to reveal the secret:
on 03/02/2018(UTC),  on 03/02/2018(UTC)
Offline Razonar
#13 Posted : 03 February 2018 03:10:15(UTC)
Razonar
Uruguay
I'm impressed! Excelent! Thanks, don't know what actues as hold but there are something there ... Now, my point is look if it can be done for external libraries, like coolprop or airy functions. And redefine diff for those cases where it fails.
Edited by user 03 February 2018 03:11:52(UTC)  | Reason: Not specified
Offline Razonar
#14 Posted : 03 February 2018 04:07:02(UTC)
Razonar
Uruguay
Oops. Integers vs rationals.
#15 Posted : 03 February 2018 06:08:01(UTC)
The line is a local definition operator.
Observe the red example: coefficients 'a' exist/defined/assigned
thus satisfy the Σ . On the other example |Σ 'c' result from calculations.
The summing operator must "steal" the 'c' via the isolating local line operator.
Differently but of same nature, DeBoor is redefined locally on the RHS.
More examples have been encountered [there was Legendre polynomials...]
Offline Razonar
#16 Posted : 04 February 2018 13:08:19(UTC)
Razonar
Uruguay
Hi. The proposed method looks excellent, but only works for integers.
So, it's a bug or what else?
#17 Posted : 04 February 2018 14:47:22(UTC)
The at() function used for applying the perturbation makes a search and replace without limiting the search expression to valid variable names. It can't, however, handle expressions as replacement targets.
The line function isn't at stake here.
on 06/02/2018(UTC)
#18 Posted : 04 February 2018 16:18:55(UTC)
More generally, the line operator is the program operator.
It may be as short as one element. Attached are three typical
applications. DeBoor is just demo, here [attached separately].
Maths Local Definition.sm (29kb) downloaded 34 time(s).
Spline De Boor [Colibri].sm (34kb) downloaded 32 time(s).
#19 Posted : 05 February 2018 09:05:18(UTC)
Maybe I don't understand what you are attempting,
if so => here is simple procedure that needs no
Uneval/re-eavl ... it just works on demand ,
wherever demanded in the work sheet.
Maths Uneval.sm (8kb) downloaded 28 time(s).
Guest (2)
