3 Pages<123>
Offline Razonar
#21 Posted : 16 February 2018 15:01:36(UTC)
Razonar
Uruguay
Originally Posted by: MBernacca Go to Quoted Post
Just an exercise on Smath to test functionalities and capabilities.
Try the attached file and play with it.
Thanks
Marco
InterX.sm (86kb) downloaded 123 time(s).
Hi Marco. Here some comments about your great file. As you suggest, I play with it.
InterX.r1.sm (78kb) downloaded 44 time(s).
on 16/02/2018(UTC)
#22 Posted : 16 February 2018 17:55:14(UTC)
1. Marco => still computing after 15 min ? !
2. Alvaro => red from top to bottom
#23 Posted : 16 February 2018 18:24:05(UTC)
Attached is about timing in work sheet.
Observe the sequential timing [black].
t0:=time(1) is in collapsed area.
Contour_8 Hypersurface.sm (1,207kb) downloaded 15 time(s).
Offline Andrey Ivashov
#24 Posted : 16 February 2018 18:31:14(UTC)
Rank: Administration
1 min 53 sec on my windows tablet pc.
Edited by user 16 February 2018 18:38:26(UTC)  | Reason: Not specified
Offline Ber7
#25 Posted : 16 February 2018 19:09:46(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
SMath Studio 0.99.6611 time(0)-to =83.735 s on my windows10
Offline ndtma
#26 Posted : 16 February 2018 19:31:34(UTC)
ndtma
Sri Lanka
Originally Posted by: Ber7 Go to Quoted Post
Originally Posted by: Andrey Ivashov [url=/forum/yaf_postsm47126_Line-intersections.aspx#post47126][/url]
SMath Studio 0.99.6611time(0)-to =83.735 son my windows10
Time taken in my win 10 laptop with SS 0.99.6619 shown.
#27 Posted : 16 February 2018 19:54:42(UTC)
5 min 25 s (win 10 x64, intel i5 quad core 2.40GHz)
#28 Posted : 16 February 2018 21:07:54(UTC)
reduced to 30-35 seconds using ranged indices to replace stack/augment/submatrix (most heavy operations were in stack/augment under loops)
InterX.r1 - ranged indices.sm (88kb) downloaded 32 time(s).
Edited by user 16 February 2018 21:09:42(UTC)  | Reason: Not specified
on 16/02/2018(UTC)
#29 Posted : 16 February 2018 21:11:46(UTC)
18 seconds on my env.
Great! Thank you Davide!
#30 Posted : 16 February 2018 21:49:26(UTC)
BTW, I would suggest to use another version of plotG which is much faster then previous one (and simplier):
Code:
plotG(x,y,char,size,color):line(k:range(1,rows(x)),augment(x,y,el(r3,k):char,el(r4,k):size,el(r5,k):color),2,1)
Code:
plotG(xy,char,size,color):line(k:range(1,rows(xy)),augment(xy,el(r3,k):char,el(r4,k):size,el(r5,k):color),2,1)
on 17/02/2018(UTC)
Offline Razonar
#31 Posted : 16 February 2018 22:18:55(UTC)
Razonar
Uruguay
Hi. Just one more thing, I guess: the only one remaining matlab function, mwfind replaced. (Orignal work have many) If I'm not wrong, it is now 100% SMath native. But double the amazing time obtained by Davide. But it's just a "scalar" implementation, sure there are better ones.
PD: I don't replace plotG because don't understand very well that syntax.
InterX.r1 - ranged indices.sm (91kb) downloaded 19 time(s).
#32 Posted : 16 February 2018 22:45:48(UTC)
It is simple - ranged indexes used.
Just take a look at the speed:
Offline Razonar
#33 Posted : 16 February 2018 22:59:17(UTC)
Razonar
Uruguay
Thanks for the explanation, now I see the speed increment, and I don't think that it could be that big difference before you show it.
But actually the plotG(4) routine was which confuse me. I prefer
Code:
plotG(xy,char,size,color):if(cols(xy)>1,plotG(col(xy,1),col(xy,2),char,size,color),plotG(Re(xy),Im(xy),char,size,color))
because I think that any good plot implementation must to use complexes but not couple of reals. So, if xy argument have only one column, one can assume that data are as Z = X + iY.
Edited by user 16 February 2018 23:02:18(UTC)  | Reason: Not specified
#34 Posted : 16 February 2018 23:08:15(UTC)
Andrey misses this detail of your function about the complex values, but you can still do it; keep the if statement and replace the loops (the case with more than a column as shown by Andrey doesn't require the col() functions, this is redundant and time consuming... If you think that more than 2 columns might be provided, add the case and a single sumbatrix instead Good )
Edited by user 17 February 2018 13:22:35(UTC)  | Reason: typo
on 16/02/2018(UTC)
Offline alyles
#35 Posted : 17 February 2018 00:24:21(UTC)
alyles
United States
Here's my pure SMATH find function. with similar time to MWFIND.
InterX.r1 - ranged indices_alyles.sm (95kb) downloaded 33 time(s).
thanks 4 users thanked alyles for this useful post.
on 17/02/2018(UTC),  on 17/02/2018(UTC),  on 17/02/2018(UTC),  on 17/02/2018(UTC)
#36 Posted : 17 February 2018 15:35:24(UTC)
Code:
Code:
For such uses it would be good if the augment and stack functions could expand scalar arguments (or more generally any arguments not matching the maximum number of rows or cols) to uniformly populated vectors of the required size).
Then the above example wouldn't even need a helper function as you could write
Code:
augment(x,y,"*",10,"red")
#37 Posted : 17 February 2018 15:39:40(UTC)
Very good suggestion, Martin! I think I could do this.
Offline omorr
#38 Posted : 17 February 2018 19:20:11(UTC)
omorr
Serbia
Code:
I also vote for that augment() and stack () functionality.
In that case, we could even have "plot" functions (with the same functionality as augment())
Code:
plot(x,y)
plot(x,y,"*")
plot(x,y,"*",10)
plot(x,y,"*",10,"red")
This efforts are, of course, not justified if the micro Mathematics plot style would be introduced.
Edited by user 17 February 2018 19:24:41(UTC)  | Reason: Not specified
on 19/02/2018(UTC)
#39 Posted : 19 February 2018 04:58:48(UTC)
Hello Marco,
I'm trying for the intersection of the two Trifolium, .
blue => native ... red => rotated.
They are created in "Page1 Trifolium.sm
Then recalled for the InterX(T1,T2)
Nothing happens >>> 1 hr ? [Win 7 Starter Edition ... 1.66 GHz]
Is it supposed to work ? Thanks in advance.
Page1 Trifolium.sm (33kb) downloaded 12 time(s).
Maths InterseX [Marco].sm (52kb) downloaded 11 time(s).
Offline Razonar
#40 Posted : 19 February 2018 06:26:16(UTC)
Razonar
Uruguay
Hi Jean.
You are using an old version of the program. Try this one.
Notice that the point (0,0) is found several times by the algorithm. It could be interesting to check if it get the correct number of crosses at the origin.
InterX.r1 - ranged indices_alyles.sm (89kb) downloaded 23 time(s).
3 Pages<123>
