Offline PWR
#1 Posted : 24 February 2018 20:08:08(UTC)
PWR
United Kingdom
I am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show?
#2 Posted : 24 February 2018 21:16:47(UTC)
Something wrong ... definitly/definitively
Please, attach the document, it may need be doctored.
Utilities Matrix Delta.sm (41kb) downloaded 14 time(s).
#3 Posted : 24 February 2018 21:31:06(UTC)
The content might be hidden if the matrix is too large (number of elements or width/height)
Check if there are ellipsis displayed on the left/bottom edges and drag them aroud to display the hidden content.
Otherwise as suggested above attach the file that doesn't work for you Good
Edited by user 24 February 2018 21:38:55(UTC)  | Reason: Not specified
on 24/02/2018(UTC)
Offline PWR
#4 Posted : 03 March 2018 15:26:37(UTC)
PWR
United Kingdom
Thanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved!
#5 Posted : 03 March 2018 17:18:45(UTC)
Problem solved <= Answer Problem NOT solved
The "ellipsis" feature [Smath 6179 ...] is convenient to display limited check from long
vector(s)/matrix ... however: can't be used to collect the entire result [it collect
what is displayed only]. To collect the entire result ... like this:
1. result
2. [result] from matrix drop down menu 1 row by 1 col
3. [result]= set decimal places, F9 to calculate
4. @ this point, you can export the entire vector/matrix.
