I am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show?
Originally Posted by: PWR I am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show? Something wrong ... definitly/definitively Please, attach the document, it may need be doctored. Utilities Matrix Delta.sm (41kb) downloaded 14 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
The content might be hidden if the matrix is too large (number of elements or width/height) Check if there are ellipsis displayed on the left/bottom edges and drag them aroud to display the hidden content. Otherwise as suggested above attach the file that doesn't work for you
Edited by user 24 February 2018 21:38:55(UTC)
Thanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved!
Originally Posted by: PWR Thanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved! Problem solved <= Answer Problem NOT solvedThe "ellipsis" feature [Smath 6179 ...] is convenient to display limited check from long vector(s)/matrix ... however: can't be used to collect the entire result [it collect what is displayed only]. To collect the entire result ... like this: 1. result 2. [result] from matrix drop down menu 1 row by 1 col 3. [result]= set decimal places, F9 to calculate 4. @ this point, you can export the entire vector/matrix.
