27 Pages«<910111213>»
Offline uni
#201 Posted : 17 March 2018 07:10:33(UTC)
uni
Quote:
I just downloaded 0.99 and it didn't work out.
Tell me more about what's wrong.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Gecko
#202 Posted : 19 March 2018 15:14:00(UTC)
Gecko
Hi Uni,
I downloaded your zip file, then copied the two dll files into the plugin folder of smath. When I then start smath I get an error message saying "The remote server returned an error: (407) Proxy Authentication Required".
Sorry I am a newbee. I am not familiar with the procedure for installing plugins. I had used mathcad in the past, and I started working a bit with smath about a year ago. I was looking for a WYSIWYG option, next to python. I do found smath rather convenient but was not so happy with the plotting options so I was curious to see how it would turn out with that plugin.
Thanks for your help.
Offline uni
#203 Posted : 19 March 2018 16:12:42(UTC)
uni
You need to use the Extension Manager (from SMath Studio main menu) to install plugins.
Russia ☭ forever
#204 Posted : 19 March 2018 16:23:44(UTC)
Before using the Extensions Manager please remove any plugin you have manually installed. Good
This is under Tools > Plugins... > Online gallery
Edited by user 19 March 2018 16:35:54(UTC)  | Reason: Not specified
on 19/03/2018(UTC)
Offline ElSid
#205 Posted : 28 March 2018 17:50:28(UTC)
ElSid
United States
Going to my heat transfer sheet ...
I was plotting the curves and started filling in the table information. The title stuck, but the X and Y labels did not.
I have tried several times, including creating a new graph, to fix these labels and the plugin freezes SMath. I need to enter task manager to end the program. Essentially, the "pop-up" associated with this plugin is not showing up.
XY-Plot Crash.sm (116kb) downloaded 52 time(s).
PS, I created a new sheet and inserted a zed graph, pop up came up. I created another new sheet and inserted a blank X-Y graph, it crashed.
Edited by user 28 March 2018 18:00:53(UTC)  | Reason: Added PS
#206 Posted : 28 March 2018 19:14:46(UTC)
Originally Posted by: ElSid Go to Quoted Post
... it crashed.
Quite OK here.
Are you doing something wrong or bug wrt your Smath version ? ?
Offline ElSid
#207 Posted : 28 March 2018 19:22:08(UTC)
ElSid
United States
Are you doing something wrong or bug wrt your Smath version?
My sheet has the app version. I'm on 0.99.6654. Looks like that may be the problem
#208 Posted : 28 March 2018 19:53:16(UTC)
I'm on 0.99.6654.Looks like that may be the problem
Conclusively, Maxima X_Y is affected by the Smath version.
Offline uni
#209 Posted : 29 March 2018 07:04:16(UTC)
uni
I can't reproduce the issue. Can you make a screenshot or save crash dump?
Russia ☭ forever
Offline ElSid
#210 Posted : 29 March 2018 15:31:38(UTC)
ElSid
United States
Issue was with SMath 0.99.6654. Andrey updated Smath to 0.99.6661 yesterday and the plugin works
Offline ElSid
#211 Posted : 13 April 2018 20:42:37(UTC)
ElSid
United States
Found the issue(s). See revamped file. Still having issues in that X-Y plot Labels for the legend *zap* Quick Sound Loss.smz (143kb) downloaded 61 time(s).
Edit: Two bugs
  1. X-Y Plot. If functions crash, *Zap* to the legend titles. All other titles OK. Legend is empty due to laziness after last 5 crashes
  2. solve(4) did not like trying to cancel units in the denominator of the final function (#dist). As I was adding units to x:0-100 FT and dividing the units meters in the function, the function crashed in the solve block (Just the function, with all values plugged in except for x = vector, so it's a solve(4) issue).
This is one of those sheets where UNITS are huge! The equations are all based off of SI/metric references. Major issue
There is additional documentation and function definition updates. Sanity check the graph x scale (adjusted for feet since I'm in the US). Should be good now
Offline Alex M.
#212 Posted : 01 June 2018 21:02:40(UTC)
Alex M.
Hi Uni,
Is XY plot still being actively developed?
I was hoping you can address the image quality when printed to PDF.
I wonder if this is because in onpaint() you convert all the draw calls to bitmap which is further stored displayed and printed. In image region, for a windows native vector EMF file, i draw the EMF directly within onpaint() which makes sure that image looks sharp on both the screen (94 dpi) and printer (300 DPI)
AM
#213 Posted : 04 June 2018 02:55:35(UTC)
PDF quality depends only upon the PDF creator. For free, CutePDF is acceptable.
No idea how it renders hard print because I don't have printer.
TESLA.pdf (60kb) downloaded 60 time(s).
Offline Alex M.
#214 Posted : 05 June 2018 01:07:17(UTC)
Alex M.
You are not using "X-Y Plot Region" but "2D Plot" in attached PDF; my comment was regarding the "X-Y Plot Region"
#215 Posted : 05 June 2018 05:57:02(UTC)
No matter X_Y region or QuickPlot ... totally identical from CutePDF.
Doublet.pdf (29kb) downloaded 43 time(s).
#216 Posted : 05 June 2018 06:02:37(UTC)
Image of the CutePDF as rendered by Adobe Reader DC.
Offline alyles
#217 Posted : 05 June 2018 15:12:23(UTC)
alyles
United States
Jean, looked at zoomed image below from your pdf.
the function text is nice and clear, the plot is pixelated. This is what the issue here.
Offline Alex M.
#218 Posted : 05 June 2018 18:19:48(UTC)
Alex M.
It does look that bitmap is being displayed / printed instead of draw calls
Code:
        public override void OnPaint( PaintEventArgs e ) {
            base.OnPaint( e );
            if ( this.InEvaluation ) return;
            Image image = new Bitmap( e.ClipRectangle.Width, e.ClipRectangle.Height );
            Rectangle Rect = new Rectangle( new Point( 0, 0 ), image.Size );
            Graphics g = Graphics.FromImage( image );
            g.FillRectangle( new SolidBrush( Color.White ), Rect );
            cs.ChartArea = Rect;
            cs.AddChartStyle( g, ca, xa, ya, y2a, gd, lb, tl );
            dc.AddCurves( g, cs, xa, ya, y2a );
            lg.AddLegend( g, dc, cs );
            e.Graphics.DrawImage( image, e.ClipRectangle );
            g.Dispose();
Uni, if you have time at some point, could you either supersample bitmap, or draw directly in onPaint() similar to what was done in PieChart:
https://smath.info:8443/!/#public/view/head/plugins/PieChartRegion/PieChartCanvas.cs
Thank you,
Alex M.
#219 Posted : 05 June 2018 20:41:39(UTC)
Originally Posted by: alyles Go to Quoted Post
Jean, look at zoomed image below from your pdf.
PDF creators recognize what is coded [text, glyphes like in equation editors ...].
The graphs are not codable and treated as image raster. When you zoom up the PDF
documents, the images are simply pixelated. If you zoom up 400%, each pixel is
quadruplated side by side thus the poor looking. If the graph could be interpreted
as an RGB image, then the PDF reader would have to process/zoom the image from
some type of image subprocessor. That simply does not exist with Adobe Reader.
I'm not aware of PDF creator/reader that process images.
In short: Smath is of no concern in there.
From recollection, my "Nuance PDF creator/reader" would zoom up like an image.
Page1 zoom Doublet.sm (110kb) downloaded 35 time(s).
#220 Posted : 06 June 2018 09:58:22(UTC)
Yes this is the cause. Try the following (drag&drop the zip in the canvas - just for testing purposes):
XYPlotRegion.zip (70kb) downloaded 33 time(s).
code committed
Edited by user 06 June 2018 20:22:45(UTC)  | Reason: Not specified
on 07/06/2018(UTC)
Guest, oscampo
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
