Offline ElSid
#1 Posted : 12 April 2018 20:10:56(UTC)
ElSid
United States
Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything?
Matrix -Insert Row or Column.sm (6kb) downloaded 45 time(s).
Edited by user 12 April 2018 20:24:20(UTC)  | Reason: Not specified
#2 Posted : 12 April 2018 20:19:30(UTC)
Cutrrently not possible: [SS-13]
Offline ElSid
#3 Posted : 12 April 2018 20:23:48(UTC)
ElSid
United States
Thank you Sad Just added a vote to this item
#4 Posted : 12 April 2018 21:42:29(UTC)
Easy/simple ... it's ADD not INSERT
Matrix -Insert Row or Column.sm (13kb) downloaded 75 time(s).
#5 Posted : 13 April 2018 02:35:51(UTC)
In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ...
Simply => submatrix !
#6 Posted : 13 April 2018 02:37:35(UTC)
simply submatrix !
Offline MarB
#7 Posted : 13 April 2018 09:26:21(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
You can use this tool. It also allows conversion between Excel and Smath.
Smath Tools:
https://smath.info/wiki/Tools.ashx
Edited by user 13 April 2018 09:35:37(UTC)  | Reason: Not specified
#8 Posted : 13 April 2018 15:04:16(UTC)
Dead like stone, better use Smath tool ! page 14
Utilities Matrix Treasury_0 Copy.sm (497kb) downloaded 61 time(s).
Offline ElSid
#9 Posted : 16 April 2018 23:24:55(UTC)
ElSid
United States
Jean,
Sometimes your convoluted solutions really do inspire ... when I understand them Good
Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (7kb) downloaded 46 time(s).
Thank you
#10 Posted : 17 April 2018 03:08:50(UTC)
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion,
reserved for Fourier 'ifft'... why did you remove it.
For common work, rater use InsertCol/InsertRow.
RS_Insert cols_rows to Matrices(1).sm (48kb) downloaded 50 time(s).
Guest (2)
