#1 Posted : 21 May 2018 01:46:13(UTC)
The ZedGraph log did crash my Smath session.
Otherwise Bode data set is 1/1 MCD.
Project Admittance Copy.sm (48kb) downloaded 68 time(s).
Offline alyles
#2 Posted : 21 May 2018 15:59:57(UTC)
alyles
United States
Fixed for ZedGraph in attached. Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Project Admittance Copy_alyles.sm (91kb) downloaded 43 time(s).
#3 Posted : 21 May 2018 17:45:19(UTC)
Originally Posted by: alyles Go to Quoted Post
Fixed for ZedGraph in attached.Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Thanks alyles, just doctored before your attachment.
I noticed ZedGraph does not support spline, unlike ordinary XY.
Project Admittance.sm (88kb) downloaded 36 time(s).
#4 Posted : 22 May 2018 03:36:17(UTC)
... [suite]
this Smath document has been doctored/finished for publishing.
Bode gain plot, phase plot ... both log plot X direction.
Project Admittance Copy.sm (151kb) downloaded 41 time(s).
#5 Posted : 22 May 2018 16:58:42(UTC)
... more general definition of phase:
Project Admittance Copy.sm (156kb) downloaded 25 time(s).
Offline alyles
#6 Posted : 22 May 2018 19:32:28(UTC)
alyles
United States
Figured out how to use Maxima's Draw2D(). This also looks nice for a logx plot. Plotted both Admittance and Phase in same graph. I like this as well because properties can be changed directly in SMath sheet.
I played around with XY Plot but was unable to find a way to use log axes.
Project Admittance Copy_Maxima_Draw2D_alyles.sm (184kb) downloaded 54 time(s).
thanks 3 users thanked alyles for this useful post.
on 22/05/2018(UTC),  on 23/05/2018(UTC),  on 23/05/2018(UTC)
#7 Posted : 22 May 2018 19:55:59(UTC)
Nice example!
I did a bit of cleanup, removed the markers and shifted some options to the settings dialog.
2018-05-22 18_50_32-SMath Studio - [Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm_].png
Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm (98kb) downloaded 99 time(s).
thanks 4 users thanked mkraska for this useful post.
on 22/05/2018(UTC),  on 22/05/2018(UTC),  on 23/05/2018(UTC),  on 23/05/2018(UTC)
