The ZedGraph log did crash my Smath session. Otherwise Bode data set is 1/1 MCD. Jean Project Admittance Copy.sm (48kb) downloaded 68 time(s).
Originally Posted by: Jean Giraud The ZedGraph log did crash my Smath session.
Fixed for ZedGraph in attached. Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings. Project Admittance Copy_alyles.sm (91kb) downloaded 43 time(s). |
Originally Posted by: alyles Fixed for ZedGraph in attached.Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings. Thanks alyles, just doctored before your attachment. I noticed ZedGraph does not support spline, unlike ordinary XY. Project Admittance.sm (88kb) downloaded 36 time(s).
... [suite] this Smath document has been doctored/finished for publishing. Bode gain plot, phase plot ... both log plot X direction. Jean Project Admittance Copy.sm (151kb) downloaded 41 time(s).
Figured out how to use Maxima's Draw2D(). This also looks nice for a logx plot. Plotted both Admittance and Phase in same graph. I like this as well because properties can be changed directly in SMath sheet. I played around with XY Plot but was unable to find a way to use log axes. Project Admittance Copy_Maxima_Draw2D_alyles.sm (184kb) downloaded 54 time(s). |
3 users thanked alyles for this useful post.
on 22/05/2018(UTC), on 23/05/2018(UTC), on 23/05/2018(UTC)
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
4 users thanked mkraska for this useful post.
on 22/05/2018(UTC), on 22/05/2018(UTC), on 23/05/2018(UTC), on 23/05/2018(UTC)
