SMath Studio Forum
Questions
[Maxima Plugin] least common multiple
Joined: 22/05/2018(UTC) Posts: 25 Location: California
Although lcm() works in Maxima... it won't work for me in Smath using Maxima(lcm()) I'm a noob but researched for hours and am non-the-wiser... Any help is much appreciated. The only result when searching the forum is a Matlab plugin which I couldn't work... plus I'm not sure lcm() is included with that plugin anyway. https://en.smath.info/forum/yaf_...tlab-C-Math-Library.aspx lcm.sm (3kb) downloaded 45 time(s).Edited by moderator 22 May 2018 13:14:53(UTC)
| Reason: added Maxima tag
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
You need to load the "functs" package in Maxima first. Seems that wxMaxima does that on startup. I could also load this package automatically if required. You can add this locally to your maxima.xml in the plugin directory (search for this file to find the directory). |
Thank you Mr. Kraska... I found a Japanese page where others had to load it on their Maxima first as well. http://web.sfc.keio.ac.jp/~yama/nos/?p=3505Also this third party Maxima manual tells users to do so as well. http://www.delorie.com/gnu/docs/maxima/maxima_95.htmlWhich turned out to actually be the instructions for SMath not Maxima. Now I suppose I'll need to write a loop in order to use the function with more than two numbers. Somewhat curious since Maxima has an ezgcd() function which accepts more than two inputs. Anyhow, I will click thanks on your profile Sir. update: When I click thank on your post an error occurs. Edited by user 23 May 2018 10:47:19(UTC)
SMath Studio Forum
Questions
