SMath Studio Forum
Questions
Approximate solution of equation system?
I have a system of n equations with m variables. Can SMath solve it approximately? Like, for example, MathCAD can with MinErr function.
Originally Posted by: Ushwood I have a system of n equations with m variables. Can SMath solve it approximately ? Like, for example, MathCAD can with MinErr function. Answer is YES as long as your "m variables" are "m parameters" and that you set a system of "m equalities" among the 'n' data sets That's how it works in Smath 6179 previous to 6671. 1. The pure parabolic example can be made slightly noisy to reflect experimental data collected. In that case, al_nleqsolve will rougly get passage at the support points. Further, Genfit Conjugate Gradient will refine on SSD. 2. The other project concludes a long collaboration in this Forum. From a 7 parameters model, it like averages a set of 7 parameters that will satisfy the 9 sets of data. Unfortunately, the data sets don't belong to an homogeneous family. All in all: Smath has done same as Mathcad 11 for > 100 fitting sessions. In many of these sessions Smath is declared superior to MCD. Jean Genfit al_ nleqsolve DIDACTIC.sm (79kb) downloaded 26 time(s). Solve al_nleqsolve Ber7_Nicolas [6179] RECONCILIATION Copy.sm (81kb) downloaded 28 time(s).
Originally Posted by: Jean Giraud 1. The pure parabolic example can be made slightly noisy to reflect experimental data collected. In that case, al_nleqsolve will rougly get passage at the support points. Further, Genfit Conjugate Gradient will refine on SSD. This is not true: al_nleqsolve will not roughly find solutions. Probably caused by the hyper-reflexive model. Genfit will find adequate parameters to the noisy data set, but diverges at the 3rd iterate. Jean Genfit al_ nleqsolve DIDACTIC.sm (85kb) downloaded 27 time(s). ... updated
SMath Studio Forum
Questions
