Offline DJ_26
#1 Posted : 20 August 2018 12:47:09(UTC)
DJ_26
United Kingdom
I am new in sMath topic. Can anybody tell me why here my combobox doesn't work correctly? It doesn't download values from rows.
Thanks!
Lifters check.sm (21kb) downloaded 43 time(s).
Edited by user 20 August 2018 12:56:49(UTC)  | Reason: Not specified
Online PompelmoTell
#2 Posted : 20 August 2018 13:12:49(UTC)
PompelmoTell
I have identified two errors:
1) you must assign a variable to the combobox
2) seems to have disabled the evaluation of the combobox
thanks 1 user thanked PompelmoTell for this useful post.
on 20/08/2018(UTC)
#3 Posted : 20 August 2018 17:40:29(UTC)
Sergio,
Your snippets and Uni snippets can't be viewed.
How do you mange to make them so microscopic !
Mines are always 1/1 from captured very fast.
Online PompelmoTell
#4 Posted : 20 August 2018 18:02:00(UTC)
PompelmoTell
Jean, did you click on the image? it should automatically expand to normal size. Later you can further enlarge it with Ctrl + (+)
on 20/08/2018(UTC)
#5 Posted : 21 August 2018 00:04:04(UTC)
Later you can further enlarge it with Ctrl ( )
Clicking on the image in the forum it expands a bit.
To view it original you have to Ctrl+ several times.
Returning to the forum, then Ctrl- as many times.
The capture method is the normal way.
The capture from WinGrab [freeware] can be pasted
directly in Paint Win 7.
I was replied by [kept anonymous] a major Smath authority
"If I don't see something, don't open"
May be not exact wording.
Thanks Sergio.
#6 Posted : 21 August 2018 02:18:20(UTC)
1. click WinGrab [task bar]
2. click "Capture" [winGrab menu]
3. F11 [or as user options] ... screen is in WinGrab
4. "Selection tool" [WinGrab menu] ... adjust selection
5. selection is done ... "Crop image" [WinGrab menu]
6. "Save as" *.PNG ... Windows remember were to save
in my box it saves in C:\Snippets.
7. Upload in Forum , bingo from the Snippet Directory.
The last saved snippet is always at top ...
double click/done in queue of the Forum.
No Ctrl+++ ... No Ctrl---- back to forum
On the image in the Forum "Copy image", Paste in Smath
Why reduce baby elephant to the mouse size ?
#7 Posted : 21 August 2018 02:41:31(UTC)
Big images might be an issue on metered connections and more in general they makes harder to navigate a thread (the spoiler bbcode is useful too in these cases); this kind of "widget" is available on almost any forum board, the image is available on full size, but is hidden behind a thumbnail. Good
However the thumbnail above it expands depending on the device, thus why it might appears tiny even when clicked depending on your screen size... in most browsers a right click on the "expanded to screen" popup allows to open the image in another tab at full size, and a download link is available on the bottom of the same popup.
Edited by user 21 August 2018 02:44:58(UTC)  | Reason: Not specified
on 21/08/2018(UTC)
#8 Posted : 21 August 2018 04:51:32(UTC)
The original image would scare a crow !
1. WinGrab capture from web
2. paste in IrfanView, Resize/Resample 87.5%
3. while in IrfanView: Sharpen twice
4. Resize/resample again 87.5%
5. Sharpen twice again
... clean, convenient size for Smath document
Offline DJ_26
#9 Posted : 21 August 2018 12:57:40(UTC)
DJ_26
United Kingdom
Sergio,
can you send me a correct file if it's not a problem?
I now what you mean but that will be the easiest way for me. I still have something incorrect.
Thanks for help
#10 Posted : 21 August 2018 14:08:53(UTC)
... alternately from work sheet Combobx
captured via WinGrab adds frame around.
Online PompelmoTell
#11 Posted : 21 August 2018 16:07:52(UTC)
PompelmoTell
this
Lifterscheck.sm (22kb) downloaded 43 time(s).
Offline DJ_26
#12 Posted : 29 August 2018 17:49:31(UTC)
DJ_26
United Kingdom
Thanks Sergio!
Unfortunately I have another problem. Combobox command "Requested element doesn't exist" and I can't find the answer. If you can, please check the file for me.
Thanks in advance! Restraint_bracket.sm (16kb) downloaded 17 time(s).
Online PompelmoTell
#13 Posted : 29 August 2018 18:34:32(UTC)
PompelmoTell
A possible way of use is as follows:
(I reduced the example to a minimum)
Restraint_bracket(sergio).sm (8kb) downloaded 48 time(s).
Offline DJ_26
#14 Posted : 06 September 2018 17:30:19(UTC)
DJ_26
United Kingdom
Thanks Sergio,
it is definitely easier way. Do you now way it's not working similar to lifters file?
And why in both files I can't add another row/column to matrix by creating value in nonexistent row/column and then recreating matrix? This manner it's not working.
Maybe any other way to easy add row/column.
Sorry to bother You.
Cheers
