Hi, This is maybe not a bug but it doesn't look very well. Result should be pure real 1 I understand why this happen and wonder if that fixable Regards Kriss
Originally Posted by: krissn Result should be pure real 1
I understand why this happen and wonder if that fixable 1. your expression is incorrect: Euler 'e' is a number 2. as it should be '1' but not computable it displays complex. 3. often, annoying but |abs| makes it computed. 4. some ancient MainFrames still have pi in numerical values [XXX decimals] 5. Advanced computing machinery use "Simon Plouffle". 6. NOT a bug: just a fact not yet fixable [expect more from Smath Geeks].
The search for 'pi' exhausted great Mathematicians [Legendre ...] not to avail. The proof to 'pi' by isoperimetres dates back to 1813 by French Geometre "Schwab" Simon Plouffe limit of 'n = infinity'
Joined: 28/08/2014(UTC) Posts: 1,371 Was thanked: 834 time(s) in 528 post(s)
Hi Kriss. You're right. It's a shame that the result isn't exact. This was call the most beautiful equation, because relates the most important numbers in the history, which came from different disciplines: calculus, geometry, complexes and natural numbers. Best regards. Alvaro.
Originally Posted by: Razonar Hi Kriss. You're right. It's a shame that the result isn't exact. Even worst if not cautious ! Annoying in the attached LinfitCheby. Was reported long time ago. GenfitLinfitCheby.sm (75kb) downloaded 13 time(s).
Seems to be working. Thanks Edited by moderator 31 October 2018 12:48:01(UTC)
| Reason: fixed in SMath Studio 0.99.6877
