Offline Andrey Ivashov
#1 Posted : 23 January 2019 00:39:35(UTC)
Rank: Administration
Was thanked: 2012 time(s) in 680 post(s)
Created by SMath LLC in the scope of SMath project. Published by smath.
  • SMath Studio box
  • Calculation of Gravitation Acceleration example
  • Example of animation on the Worksheet
  • Extensions Manager tool
  • Opened math Reference Book
  • SMath Viewer output to Autocad example
  • SMath Studio on iOS
  • SMath Studio on iPad
They trust us *
* Customers' names and logos are used with the written permission of the copyright holders.
They talk about us (all reviews...)
  • Excelente alternativa para reemplazar a Mathcad, me ha ayudado mucho en mi carrera de Ingeniaría Civil, me suscribí al plan anual, gracias.
    by Cristian Yamid Pérez Peña
  • As a Civil Engineering professor, I've realized to be hard to find a software suitable for both introductory and advanced subjects. SMath is the only free software I know to get the job done. Try it out.
    by João Felipe Melo
  • Świetny soft, prawdziwy life saver, rewelacja.
    by AA
  • Es un imprescindible para el día a día. Muchísimas gracias Mr Andrey Ivashov.
    by Ángel Álvarez
  • Congratulations!! This software is amazing!! An almost complete substitution for Mathcad!!
    by Hervandil Sant'Anna
  • trop bien ce programme....pour faire de fiches de calcul. en plus on peut ouvrir des fiches Mathcad sans souci aucun.
    by aedes
  • A very useful tool for engineers. Thanks a lot. Keep up the great work.
    by Bhargav
  • This tool is amazing. It helped me on my university more times than i can imagine.
    by Radek
  • Simple and Elegant
    by Egbert Sales
  • Excelente software para cálculo. La interface tipo papel la hace muy versátil y amigable. La recomiendo ampliamente.
    by Tomás Soto
SMath Studio in publications (all publications...)
SMath Studio plug-ins (all plug-ins...)
The functionality of the program can be expanded through the installation of plug-ins created by third-party developers and companies, as well as those prepared by the SMath LLC team. Most plug-ins are open source and can be modified if necessary.
  • Extends SMath Studio with a 3D Plot Region.
    Jack Xu, Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with more save/import/export features.
    Davide Carpi (davide.carpi@gmail.com)
  • Access to a set of programs for calculating properties of water, steam, gases and gases mixtures. Requires separate installation of the Water Steam Pro libraries and appropriate license for it (see http://www.wsp.ru/).
    ООО "ЭсМат"
  • Provides access to the free and open source computer algebra system Maxima.
    Kay Graubmann & Martin Kraska (THB www.th-brandenburg.de)
  • Extends SMath Studio with a X-Y Plot Region.
  • A SMath Studio native wrapper of the CoolProp library (www.coolprop.org) - thermophysical property database and wrappers for a selection of programming environments.
    Mike Kaganski
  • Contains nonlinear solvers for equations and systems of equations: Bisected Direct Quadratic Regula Falsi (BDQRF), Bisection, Brent's, Broyden's, Homotopy, Newton-Raphson, Ridder's, Secant, etc.
  • Digital Signal Processing Library: spectral analysis, IIR and FIR filters, resampling algorithms, etc.
    Sergey Bakhurin (http://dsplib.org), Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with statistical tools: Sample Estimators, Probability Density, Cumulative Density, Quantile functions, Random Numbers, etc.
  • Provides an interface to the SQLite relational database engine.
    Chris Bietz, Viacheslav N. Mezentsev
Please note:
  1. There are some known bugs with Worksheet scrolling - will be addressed soon;
  2. There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
    Please use the following to disable high dpi support if required:
To all developers:
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
thanks 5 users thanked Andrey Ivashov for this useful post.
on 23/01/2019(UTC),  on 23/01/2019(UTC),  on 23/01/2019(UTC),  on 23/01/2019(UTC),  on 23/01/2019(UTC)
Offline overlord
#2 Posted : 24 January 2019 23:35:53(UTC)
Turkey
Was thanked: 548 time(s) in 368 post(s)
I have always thought those ones looks weird, especially when they are printed.
- Pi
- Euler's number
- Booelan Equal
- Infinity
It's up to developer to "correct" them anyway. But it is just frustrating to change them in PDF manually Good)
#3 Posted : 25 January 2019 01:06:26(UTC)
- Pi
- Euler's number
- Booelan Equal
- Infinity
Hello.
What you do not like exactly? Font? Style (bold)? Both?
Offline overlord
#4 Posted : 25 January 2019 08:17:30(UTC)
Turkey
for infinity, the size.
for pi/euler/boelan equal, the thickness. they should not to be bold actually.
Offline overlord
#5 Posted : 31 January 2019 09:29:03(UTC)
Turkey
Originally Posted by: Andrey Ivashov Go to Quoted Post
Hello.
By taking into consideration of the silence, should I not wait for change for them?
#6 Posted : 31 January 2019 10:39:17(UTC)
Was thanked: 1177 time(s) in 752 post(s)
As for pi and e, you can easily get rid of the bold face.
Actually, it would be sufficient to just give pre-defined values an upright face.
In the equations below, the rhs pi and e should be bold, shouldn't they?
I like the idea of the boolean equal being visually different from the evaluation operator
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
