Świetny soft, prawdziwy life saver, rewelacja.
more...
by AA
This fantastic free alternative to Mathcad is going from strength to strength and I am really enjoying watching its progress. Andrey has produced something that is genuinely useful, multiplatform, fun to use and, most importantly of all, he listens to his users. Well worth a download.
more...
by Beerus
Es excelente, me resulta más eficiente si la comparamos con las herramientas que se le parecen
more...
by Carlos Daniel Encarnación Zúñiga
Please note: - There are some known bugs with Worksheet scrolling - will be addressed soon;
- There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
Please use the following to disable high dpi support if required:
To all developers: As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement: - Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.or - All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect. All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono). Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself. Best regards, Andrey Ivashov.
on 23/01/2019(UTC), on 23/01/2019(UTC), on 23/01/2019(UTC), on 23/01/2019(UTC), on 23/01/2019(UTC)
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
I have always thought those ones looks weird, especially when they are printed. - Pi - Euler's number - Booelan Equal - Infinity It's up to developer to "correct" them anyway. But it is just frustrating to change them in PDF manually ) Regards
Originally Posted by: overlord I have always thought those ones looks weird, especially when they are printed. - Pi - Euler's number - Booelan Equal - Infinity Hello. What you do not like exactly? Font? Style (bold)? Both? Best regards.
for infinity, the size. for pi/euler/boelan equal, the thickness. they should not to be bold actually.
Originally Posted by: Andrey Ivashov
Hello.
By taking into consideration of the silence, should I not wait for change for them? Regards
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
As for pi and e, you can easily get rid of the bold face. Actually, it would be sufficient to just give pre-defined values an upright face. In the equations below, the rhs pi and e should be bold, shouldn't they? I like the idea of the boolean equal being visually different from the evaluation operator |
