They talk about us
Niezwykle przejrzyste narzędzie. Świetne do sprawdzenia czegoś na szybko, naturalne jak pisanie w zeszycie. Silna alternatywa dla MathCADa, zdecydowanie godny polecenia!
more...
by mati
Imagine combining Microsoft Word with the ability to compute every time you press equals. Best application for your engineering documentation needs!
more...
by Michael James Quidilla
As a civil engineer, over the years I have frequently used MathCAD for not only performing but also documenting calculations. With PTC dropping perpetual licensing, my recommendation to all the junior engineers I train is to give SMath Studio a serious look. While not a turnkey replacement for MathCAD, it provides most of the functionality and power at an incredible price. Already a wonderful program filling a key niche spot between a numerical calculator like Octave, and a CAS like Maxima, the expanding plugin and 3rd party development is on the rise and this project's future keeps getting even brighter. Much consideration must be given by any engineer or business before they settle on a software for adopting into the workflow. Although not open-source in the strictest sense, the development community is similar to what you would find in any first class OSS software project. The current owner of the SMath Project has also agreed to release the source code under open source license should he not be able to continue the project. So do not let the cost (your time) of learning SMath Studio and migrating your MathCAD computation sheets scare you. This project is here to stay.
more...
by Michael Fuller, P.E., PMP
on 14/02/2019(UTC), on 15/02/2019(UTC), on 15/02/2019(UTC), on 15/02/2019(UTC), on 15/02/2019(UTC), on 15/02/2019(UTC), on 19/02/2019(UTC)
Спасибо. Теперь функции работают значительно быстрее. Вернулась старая проблема с настройками страницы - не сохраняются настройки при нажатии на кнопку "Использовать по-умолчанию". Вернее они для файла сохраняются, но показывает, что не сохранились. А вот глобально не сохраняются. Небольшое кино
Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
Hi Andrey, since I'm using SMath mainly for office work, I'm always struggling between the temptation of "instant updating" to the latest (even if beta) build in order to have all the new cool features, and the conservative approach to wait for the official stable release and stay safe with my library of .sm files. Up to now, I have been able to resist and stay on the safe path, but the "dark side is calling" Recently a lot of nightly builds have been issued, so I'm wondering if you are planning to upload in a short time a stable release to consolidate all the updates that have been placed here and there in the betas? Or do you think that a stable release will not follow shortly? In other words, in case a stable release is not planned in the upcoming weeks, I might think to update on a backup machine and test the existing files there. Infact, there are some features which I'd like to use (i.e. upgraded syntax highlighting, etc..)
You can always download the Mono.tar.gz package and go for a portable test version |
Originally Posted by: Davide Carpi You can always download the Mono.tar.gz package and go for a portable test version Да, это действительно удобно. Портативную версию уже использую лет 5
Originally Posted by: genf Вернулась старая проблема с настройками страницы - не сохраняются настройки при нажатии на кнопку "Использовать по-умолчанию". Так а сохранение размера бумаги я и не делал Сохраняется только ориентация страниц, колонтитулы и т.п. С размером были какие-то проблемы. Как-нибудь посмотрю туда ещё раз...
Hello. Originally Posted by: fedeghi Recently a lot of nightly builds have been issued, so I'm wondering if you are planning to upload in a short time a stable release to consolidate all the updates that have been placed here and there in the betas? Or do you think that a stable release will not follow shortly? The reason of why we have so many beta versions since latest available stable is that there are several major changes were done to the logic of saving/opening files and rendering Worksheets. These changes must be tested well before going to the wild world As for today I see no any new significant errors reported + all automated tests I have are also passed ok, so I'm thinking about latest nightly builds as about release candidates. These versions seems stable enough to use them. Regarding next stable release - I plan to publish it on 1-st March. The main reason of it is that I need to test/prepare Cloud version as well as iOS/Android/UWP versions to make one-shot-release. There are plenty of work to perform... Best regards.
Thanks for the info!
Бывает в версии 6984 при открытии файла происходит очень долгий расчет ... приходится прерывать и обновлять - при обновлении все быстро считается. См. киноКак правило такие долгие расчеты происходят при первом открытии файла, но не всегда. Это исправлено в 6988?
