Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
Can text be included in an if statement? For example: If "Thin-walled pipe anchored throughout" then P=1-v. I have various conditions that different formulas would be used depending on the conditions, see below.
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Hi. You have some options for do that. Here are two: Best regards. Alvaro.
Originally Posted by: Razonar You have some options for doing that. Easy to complete the conditions, thus the project. Cheers Alvaro ... Jean
I don't understand how to input the data into the statement. If I press the space key, the input ends, and I cannot input anything.
Originally Posted by: Britt1 I don't understand how to input the data into the statement. If I press the space key, the input ends, and I cannot input anything. There is no space key to press. Construct the snippet, done.
Sorry, I have never constructed a snippet before. How do I do that?
Originally Posted by: Britt1 Sorry, I have never constructed a snippet before. How do I do that? Construct the math regions as per the image that we call snippet.
I tried to construct it. My question is how to do that. I try and the below is what happens:
g(str,x):=then from menu f(x), then cases, then fill-in
Joined: 14/09/2013(UTC) Posts: 90 Was thanked: 24 time(s) in 16 post(s)
The cases() function is included into the "custom functions" plugin, so you should also be sure to have it installed.
1 user thanked fedeghi for this useful post.
Originally Posted by: fedeghi The cases() function is included into the "custom functions" plugin, so you should also be sure to have it installed. Thank you. I had the "custom functions" plugin installed, but the use of it is not in any of the manuals, at least not that I could find. I had no idea I had to type the word "cases" to get to the input.
Originally Posted by: Jean Giraud g(str,x):=then from menu f(x), then cases, then fill-in Thank you. I understand now.
Originally Posted by: Britt1 I had no idea I had to type the word "cases" only click the function 'cases' from the f(x) menu. In the right most place holder of the first 'if' place the cursor type coma, coma [,,] that gives another line of conditions ... and so on.
Originally Posted by: Jean Giraud Originally Posted by: Britt1 I had no idea I had to type the word "cases" only click the function 'cases' from the f(x) menu. In the right most place holder of the first 'if' place the cursor type coma, coma [,,] that gives another line of conditions ... and so on. Thank you. I was trying to figure out how to do that.
Originally Posted by: Jean Giraud Originally Posted by: Razonar You have some options for doing that. Easy to complete the conditions, thus the project. Cheers Alvaro ... Jean I use the cases function to type everything in, but when I go back to the first line that says "x if str", as soon as I type "x if str =, as soon as I type the = sign, I get "x not defined". I am trying to understand, but not getting it yet. I had it almost working, but then this glitch appeared.
Originally Posted by: Britt1 Originally Posted by: Jean Giraud Originally Posted by: Razonar You have some options for doing that. Easy to complete the conditions, thus the project. Cheers Alvaro ... Jean I use the cases function to type everything in, but when I go back to the first line that says "x if str", as soon as I type "x if str =, as soon as I type the = sign, I get "x not defined". I am trying to understand, but not getting it yet. I had it almost working, but then this glitch appeared. I figured out how I did it before. I cannot type the = in the above, but it works with a :=. But it does not really work, because if I say str:="b" and x:=7, the answer is 21.99 instead of 14, but it does allow me to type it. I am confused.
Originally Posted by: Britt1 I figured out how I did it before. I cannot type the = in the above, but it works with a :=. But it does not really work, because if I say str:="b" and x:=7, the answer is 21.99 instead of 14, but it does allow me to type it. I am confused.
Originally Posted by: Britt1 Originally Posted by: Britt1 Originally Posted by: Jean Giraud Originally Posted by: Razonar You have some options for doing that. Easy to complete the conditions, thus the project. Cheers Alvaro ... Jean I use the cases function to type everything in, but when I go back to the first line that says "x if str", as soon as I type "x if str =, as soon as I type the = sign, I get "x not defined". I am trying to understand, but not getting it yet. I had it almost working, but then this glitch appeared. I figured out how I did it before. I cannot type the = in the above, but it works with a :=. But it does not really work, because if I say str:="b" and x:=7, the answer is 21.99 instead of 14, but it does allow me to type it. I am confused. Please post the worksheet or a screenshot. In the second column of cases you have to use boolean equals, not the assignment operator. You can find the boolean operators in one of the palettes on the right of your screen, hovering the mouse hover the symbols you should see the keyboard shortcut. |
thank you. I can't use the "Thank" button because every time I do, it says "error occurred"
Originally Posted by: Jean Giraud Originally Posted by: Britt1 I had no idea I had to type the word "cases" only click the function 'cases' from the f(x) menu. In the right most place holder of the first 'if' place the cursor type coma, coma [,,] that gives another line of conditions ... and so on. How do I remove a line. I tried backspacing, and it did not work.
