2 Pages12>
Offline Britt1
#1 Posted : 01 May 2019 23:40:54(UTC)
Britt1
United States
Can text be included in an if statement? For example:
If "Thin-walled pipe anchored throughout" then P=1-v.
I have various conditions that different formulas would be used depending on the conditions, see below.restraints.png
Offline Razonar
#2 Posted : 02 May 2019 00:24:24(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Hi. You have some options for do that. Here are two:
#3 Posted : 02 May 2019 04:04:46(UTC)
Originally Posted by: Razonar Go to Quoted Post
You have some options for doing that.
Easy to complete the conditions, thus the project.
Cheers Alvaro ... Jean
Offline Britt1
#4 Posted : 02 May 2019 23:41:07(UTC)
Britt1
United States
I don't understand how to input the data into the statement. If I press the space key, the input ends, and I cannot input anything.
#5 Posted : 02 May 2019 23:47:44(UTC)
There is no space key to press. Construct the snippet, done.
Offline Britt1
#6 Posted : 03 May 2019 00:04:03(UTC)
Britt1
United States
Sorry, I have never constructed a snippet before. How do I do that?
#7 Posted : 03 May 2019 01:05:13(UTC)
Construct the math regions as per the image that we call snippet.
Offline Britt1
#8 Posted : 03 May 2019 16:15:42(UTC)
Britt1
United States
I tried to construct it. My question is how to do that. I try and the below is what happens:if statement.png
#9 Posted : 03 May 2019 19:09:07(UTC)
g(str,x):=then from menu f(x), then cases, then fill-in
Offline fedeghi
#10 Posted : 03 May 2019 20:11:45(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
The cases() function is included into the "custom functions" plugin, so you should also be sure to have it installed.
thanks 1 user thanked fedeghi for this useful post.
on 03/05/2019(UTC)
Offline Britt1
#11 Posted : 03 May 2019 22:16:46(UTC)
Britt1
United States
Thank you. I had the "custom functions" plugin installed, but the use of it is not in any of the manuals, at least not that I could find. I had no idea I had to type the word "cases" to get to the input.
Offline Britt1
#12 Posted : 03 May 2019 22:19:43(UTC)
Britt1
United States
Thank you. I understand now.
#13 Posted : 03 May 2019 23:37:20(UTC)
only click the function 'cases' from the f(x) menu.
In the right most place holder of the first 'if'
place the cursor type coma, coma [,,]
that gives another line of conditions ... and so on.
Offline Britt1
#14 Posted : 03 May 2019 23:48:24(UTC)
Britt1
United States
Thank you. I was trying to figure out how to do that.
Offline Britt1
#15 Posted : 07 May 2019 19:15:44(UTC)
Britt1
United States
I use the cases function to type everything in, but when I go back to the first line that says "x if str", as soon as I type "x if str =, as soon as I type the = sign, I get "x not defined". I am trying to understand, but not getting it yet. I had it almost working, but then this glitch appeared.
Offline Britt1
#16 Posted : 07 May 2019 19:39:45(UTC)
Britt1
United States
I figured out how I did it before. I cannot type the = in the above, but it works with a :=. But it does not really work, because if I say str:="b" and x:=7, the answer is 21.99 instead of 14, but it does allow me to type it. I am confused.
#17 Posted : 07 May 2019 20:54:10(UTC)
#18 Posted : 07 May 2019 21:18:13(UTC)
Please post the worksheet or a screenshot. In the second column of cases you have to use boolean equals, not the assignment operator.
You can find the boolean operators in one of the palettes on the right of your screen, hovering the mouse hover the symbols you should see the keyboard shortcut.
Offline Britt1
#19 Posted : 07 May 2019 21:26:07(UTC)
Britt1
United States
thank you. I can't use the "Thank" button because every time I do, it says "error occurred"
Offline Britt1
#20 Posted : 07 May 2019 21:31:51(UTC)
Britt1
United States
How do I remove a line. I tried backspacing, and it did not work.
2 Pages12>
