Offline manti7
#1 Posted : 16 August 2019 18:18:08(UTC)
manti7
I think the vectorize() command goes too deep in the example. Probably it takes the first row from the first matrix, then it probably tries to multiply it with the second vector. Then I get the error message: Number of rows and/or columns of matrices or vectors do not match.
I think it should multiply the matrices first and then apply the comparison per line.
Can somebody take a look at this, please?
matrix_nested_function.sm (12kb) downloaded 8 time(s).
Edited by user 16 August 2019 19:45:23(UTC)  | Reason: Not specified
Offline CBG
#2 Posted : 16 August 2019 20:05:19(UTC)
CBG
Maybe this is a simple way to solve the problem
matrix_nested_function_CBG.sm (12kb) downloaded 5 time(s).
Offline alyles
#3 Posted : 16 August 2019 20:07:39(UTC)
alyles
United States
Can eval input to f() as such
matrix_nested_function_alyles.sm (13kb) downloaded 9 time(s).
Offline manti7
#4 Posted : 16 August 2019 20:50:18(UTC)
manti7
Thank you both for the quick answer! I didn't know there was an eval() function. I now understand that SMath resolves everything as low as possible and then calculates in one go. The use of eval() in the right place prevents this.
#5 Posted : 16 August 2019 22:51:54(UTC)
Maybe you complicate matters or not make it simpler from the truth table.
#6 Posted : 16 August 2019 22:55:56(UTC)
... some stuff Truth table
Utilities Matrix Truth Table [Locate row_col].sm (44kb) downloaded 13 time(s).
