SMath Studio Forum
Questions
vectorise() go to deep without first calculating the matrix product
I think the vectorize() command goes too deep in the example. Probably it takes the first row from the first matrix, then it probably tries to multiply it with the second vector. Then I get the error message: Number of rows and/or columns of matrices or vectors do not match. I think it should multiply the matrices first and then apply the comparison per line. Can somebody take a look at this, please? matrix_nested_function.sm (12kb) downloaded 8 time(s).Edited by user 16 August 2019 19:45:23(UTC)
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
Thank you both for the quick answer! I didn't know there was an eval() function. I now understand that SMath resolves everything as low as possible and then calculates in one go. The use of eval() in the right place prevents this.
Originally Posted by: manti7 I think it should multiply the matrices first and then apply the comparison per line. Maybe you complicate matters or not make it simpler from the truth table.
SMath Studio Forum
Questions
