Hi;
Why is it so hard to create a table with Smath studio ? Is there a procedure to follow step by step?
best regards.
Tables mathematically are arrays (managed in native mode in smath). To obtain tables with formal function of data contained in matrices (aesthetically similar to excel) you can use the plugin "table region" by Davide Carpi of which you can find documentation here in the forum in the folder "Extension" with numerous examples and demonstrations of use. Table Region Pluginsergio
Thank you Sergio for your reply and the link. I'll to at it in details.
best regards.
Originally Posted by: Yibbou Why is it so hard to create a table with Smath studio ? Is there a procedure to follow step by step? Tables construct by themselves from the maths. Table Matrix.sm (33kb) downloaded 108 time(s). Inst_Colebrook Pipe Data.sm (62kb) downloaded 65 time(s).
Thank you Jean, So what is the best and easiest way to fill the table elements ? best Edited by user 02 September 2019 21:45:12(UTC)
Originally Posted by: Yibbou So what is the best and easiest way to fill the table elements ? If the matrix [Table] does not result from maths, then construct manually. You can address elements much bigger job, reserved for unique/specific/repetitive projects. Typical attached. Utilities Matrix [Parse Lookup, Truth Table].sm (28kb) downloaded 88 time(s).
