Offline Yibbou
#1 Posted : 02 September 2019 14:02:10(UTC)
Yibbou
Rank: Member
Senegal
Hi;
Why is it so hard to create a table with Smath studio ?
Is there a procedure to follow step by step?
best regards.
Offline PompelmoTell
#2 Posted : 02 September 2019 15:55:15(UTC)
PompelmoTell
Tables mathematically are arrays (managed in native mode in smath).
To obtain tables with formal function of data contained in matrices (aesthetically similar to excel) you can use the plugin "table region" by Davide Carpi of which you can find documentation here in the forum in the folder "Extension" with numerous examples and demonstrations of use.
Table Region Plugin
Offline Yibbou
#3 Posted : 02 September 2019 18:52:05(UTC)
Yibbou
Rank: Member
Senegal
Thank you Sergio for your reply and the link.
I'll to at it in details.
best regards.
#4 Posted : 02 September 2019 21:06:08(UTC)
Tables construct by themselves from the maths.
Table Matrix.sm (33kb) downloaded 107 time(s).
Inst_Colebrook Pipe Data.sm (62kb) downloaded 64 time(s).
Offline Yibbou
#5 Posted : 02 September 2019 21:43:10(UTC)
Yibbou
Rank: Member
Senegal
Thank you Jean,
So what is the best and easiest way to fill the table elements ?
best
Edited by user 02 September 2019 21:45:12(UTC)  | Reason: Not specified
#6 Posted : 03 September 2019 02:05:16(UTC)
If the matrix [Table] does not result from maths,
then construct manually. You can address elements
much bigger job, reserved for unique/specific/repetitive projects.
Typical attached.
Utilities Matrix [Parse Lookup, Truth Table].sm (28kb) downloaded 87 time(s).
